Stress and strain. young modulus
In summary, the conversation discusses the process of finding the change in AB, AD, and AC using different equations such as \sigmaxx=E*\epsilonxx and \deltaAB=\epsilonAB*AB. However, it is pointed out that this is only applicable for uniaxial loading and for plane stress/strain, equations such as \epsilonxx=\sigmaxx/E - \upsilon/E*\sigmayy should be used. It is also suggested to look at the hypotenuse of the strained lengths instead of using different coordinate systems.
Dell
590
in the following question, how do i find the changle in AB, the change in AD and the change in AC?
http://lh4.ggpht.com/_H4Iz7SmBrbk/Sv_hYT83rYI/AAAAAAAAB8s/7l5YRXMxVfQ/s912/Capture.JP what i have done is used the following
[tex]\sigma[/tex]xx=E*[tex]\epsilon[/tex]xx
[tex]\delta[/tex]AB=[tex]\epsilon[/tex]AB*AB
since AB is on the x axis,
[tex]\epsilon[/tex]AB=[tex]\epsilon[/tex]xx=[tex]\sigma[/tex]xx/E=150000000/200000000000=3/400
[tex]\delta[/tex]AB=[tex]\epsilon[/tex]AB*AB=(3/400)*100*10^-5=75[tex]\mu[/tex]m
but, 1st of all this is wrong! the correct answer is meant to be 60[tex]\mu[/tex]m, and second of all it seems too simple, why would [tex]\nu[/tex]=0.3 be given if i don't use it?
The equation [itex]\sigma=E\epsilon[/itex] only applies to uniaxial loading of a long, thin object (like a rod or a beam). Do you know of a more general equation for 2-D or 3-D loading configurations?
(This http://john.maloney.org/Papers/Generalized%20Hooke%27s%20Law%20%283-12-07%29.pdf" about stresses, strains, and constitutive equations may be helpful.)
dont think so, what equation can i use?
Did you look at the link? Let me put it this way: strain in a certain direction can arise from a load in that direction, but it can also arise from lateral contraction caused by a load in another direction. Know what I mean?
Maples is right.
You should be using the equations for PLANE stress/strain and not AXIAL stress/strain. For axial strain ONLY, you would solve [tex]\epsilon[/tex]xx=[tex]\sigma[/tex]xx/E.
For plane strain, use
[tex]\epsilon[/tex]xx=[tex]\sigma[/tex]xx/E - [tex]\upsilon[/tex]/E*[tex]\sigma[/tex]yy
and comparably
[tex]\epsilon[/tex]yy=[tex]\sigma[/tex]yy/E - [tex]\upsilon[/tex]/E*[tex]\sigma[/tex]xx.
When you [positively] load a member in direction x, it elongates in that direction. In order to hold the volume of the material constant**, the object will "thin" in the other two directions y and z. The amount that they thin is described by Poisson's Ratio [tex]\upsilon[/tex].
**Note: The volume of the material can change slightly, but for loading within the normal range of the material's limits, the change will be imperceptible.
Hope this gets you on your way.
okay got is, hookes law right??
for questions a and b it worked perfectly since AB and AD lie on the X and Z axes and i have all the info i need for them, for c) i need to find the change in the length in AC which is on a differend axis system, let's call it n-y-t. now i know that the angle between them is 53.12 (atan(100/75) ) but i want the other angle,- 90+53.13 since i want the strain which goes along AC and i have the transformations equations for stress/strains
so i looked for the strain[tex]\epsilon[/tex]t
[tex]\epsilon[/tex]t=[tex]\epsilon[/tex]x*cos2(143.13)+[tex]\epsilon[/tex]z*sin2(143.13)=2.86*10-4
[tex]\delta[/tex]AB=[tex]\epsilon[/tex]t*AB=2.86*10-4*125*10-3=35.75[tex]\mu[/tex]m
which is way off, anyone see where I am going wrong?
Instead of messing around with different coordinate systems, why not just look at the hypotenuse of the right triangle?
i learned that that wouldn't work since these are not vectors, but i figured it out anyways, i was using the wrong angle.
(looking at the answers pythagoras won't work here --> 60^2+20.6^2 is not 60.4^2)
I'm talking about the hypotenuse of the strained lengths: the hypotenuse of 100.060mm and 75.0206mm is 125.0604mm.
nice
FAQ: Stress and strain. young modulus
What is stress?
Stress is a measure of the force per unit area applied to an object. It is the amount of internal force that an object experiences due to an external load or force.
What is strain?
Strain is a measure of the deformation or change in shape of an object when subjected to stress. It is the ratio of the change in length or shape to the original length or shape of the object.
What is the young modulus?
The young modulus, also known as the modulus of elasticity or elastic modulus, is a measure of the stiffness or rigidity of a material. It is the ratio of stress to strain within the elastic limit of a material.
How is the young modulus calculated?
The young modulus is calculated by dividing the stress (force per unit area) by the strain (change in length or shape divided by the original length or shape) within the elastic limit of a material. It is expressed in units of pressure, such as pascals (Pa) or newtons per square meter (N/m²).
What factors can affect the young modulus?
The young modulus can be affected by various factors, including the composition and structure of the material, temperature, and the presence of impurities or defects. Additionally, the young modulus can also vary depending on the direction in which the force is applied, as some materials may be more resistant to deformation in certain directions.
