Stress at half of tensile strength
In summary, both objects are subjected to the same stress since they are both being subjected to 50% of their respective tensile strengths.
Ron77
Can you guys solve a debate for me?If you have two objects and apply a physical stress to them, let's say in the forum of pressure.
First object: Tensile strength 400 lbs. and you apply 200 lbs
Second object: Tensile strength 200 lbs and you apply 100 lbs.
So each is under 1/2 it's tensile strength.
The debate:
Choice A: First object is under twice the stress since the load is double
Choice B: Both are under the same stress since each are being subjected to 50% of their max.
Thanks,
Ron
Depends, do the two objects have the same cross-sectional area?
The larger object has twice the cross sectional area._____________________________________________________________
Where this debate stems from:
It's concerning weightlifting. The details are this:
A person is just starting out. Say they are able to curl 50 lbs 10 times and this induces a certain amount of muscular stress. Then, years later, after their muscles have increased in CSA (cross sectional area) they can now curl 100 lbs 10 times. Would the stress to their muscles be the same since they are now larger and stronger and it's still the same percentage of strength. I'm saying yes it's the same stress since stress is relative to 'what is being stressed and it's present condition'.
My example was that if you had two objects, one with tensile strength of 100 and you applied 100, and a second object with a tensile strength of 200 and you applied 150, that even though 150 is greater, it's less stressful since it's a smaller percentage of the tensile strength of the second object,
Object one: tensile 100 applied 100
Object two: tensile 200 applied 150
__________________________________________________________________________
I had found these,
http://en.wikipedia.org/wiki/Stress_(physics )
In the more general setting of continuum mechanics, stress is a measure of the internal distribution of force per unit area that balances and reacts to the external loads or boundary conditions applied to a body.
http://www.answers.com/topic/stress-physics
Britannica
In the physical sciences and engineering, the force per unit area within materials that arises from externally applied forces, uneven heating, or permanent deformation. Normal stress refers to the stress caused by forces that are perpendicular to a cross-section area of the material. Shear stress arises from forces that are parallel to the plane of the cross section. Stress is expressed as the quotient of a force divided by an area.
Science
In physics, the internal resistance of an object to an external force that tends to deform it.
Hi Ron.
First, you're using the term "tensile strength" incorrectly. Tensile strenth is measured in force per unit area. It is the stress at which something is expected to break. Also called "ultimate tensile strength".
To determine "stress" or "tensile stress" in something such as a bar, take the force being resisted and divide by the area. Units are in force per unit area. (ex: psi)
Q_Goest said:
Hi Ron.
Ah ok, oops :blushing: forget the term tensile then.Basically, I'm just trying to query on the term 'stress' and how it applies to physical objects.
In more basic terms then, (assume all else is relatively equal, joints, leverages, ect etc.)
Person A's bicep CSA of 25 with 100 lbs
Person B's bicep CSA of 50 with 200 lbs
In reference to the term 'stress' would both biceps feel the same stress?
Yes, stress([itex]\sigma[/itex]) is defined as force per unit area ([itex]\sigma = F/A[/itex]). So, although person B exerts twice the force, his biceps have a CSA twice that of person A; so both person's biceps are under the same stress.
Thanks much, much appreciated :)
FAQ: Stress at half of tensile strength
What is "Stress at half of tensile strength"?
"Stress at half of tensile strength" is a measure of the amount of force or load that a material can withstand before it begins to deform or break. It is typically expressed in units of pressure, such as pounds per square inch (psi) or megapascals (MPa).
What factors can affect the "Stress at half of tensile strength" of a material?
The "Stress at half of tensile strength" of a material can be influenced by various factors, including the type and composition of the material, its temperature, and any external forces acting upon it. Other factors such as the material's manufacturing process and any defects or imperfections can also impact its "Stress at half of tensile strength".
Why is "Stress at half of tensile strength" important to understand?
Understanding the "Stress at half of tensile strength" of a material is crucial for determining its strength and durability. It can help engineers and scientists select the appropriate materials for various applications, such as building structures or designing products. Knowing the "Stress at half of tensile strength" can also help prevent material failure and potential accidents.
How is "Stress at half of tensile strength" measured?
The "Stress at half of tensile strength" of a material is typically measured through a tensile strength test. This involves applying a gradually increasing force to a sample of the material until it breaks. The point at which the material begins to deform or fail is recorded as its "Stress at half of tensile strength".
Can the "Stress at half of tensile strength" of a material change over time?
Yes, the "Stress at half of tensile strength" of a material can change over time due to factors such as exposure to environmental conditions, aging, and wear and tear. It is important to regularly test and monitor the "Stress at half of tensile strength" of materials to ensure their safety and effectiveness in various applications.
