ridiculoid
- 19
[/B]
I can't seem to get the image links to work sorry! Also, I think the question is supposed to say 2.5mm radius notch, not 10mm
https://imgur.com/Klxw4gG
https://imgur.com/C9d81Rl
https://imgur.com/7H421ou
[/B]
q = Ka - 1 / Kt - 1
M = Fd
(σa / σ'e) + (σm / σy) = 1/FoS
[/B]
From the stress concentration and notch sensitivity graphs, I found that D/d is 1.82, r/d 0.114 and q = 0.82. From this, Kt for the shaft under tension is 2.25 and Kt for the shaft under bending is 1.88.
For question part (c), I need to use the equation q = Ka-1 / Kt-1 rearranged to Ka = 1 + q(Kt - 1).
What I am wondering is which value of Kt I need to use, my first thought is to use 2.25 because this will give higher stress values which you would need when designing.
I am also stuck with question part (e). With all other examples I have done in class or from worksheets, the shaft has been a single step with a fillet or something similar. I am struggling to find any source material for a notched shaft under tension. I need to take moments around the point of highest stress, I am just unsure where that point is in a notched shaft. My initial thought is the center of the notch but on a single stepped shaft with a fillet, it is at the top edge but wouldn't this mean that you would disregard the 5kN force as M = Fd, M = 5 x 0?
Any help would be greatly appreciated!
