Stress, Strain, and Sound in a Projectile Steel Rod
In summary, the conversation discusses a physics problem involving a steel rod being fired at a very hard wall. The first part involves calculating the speed of a one-dimensional compressional wave along the rod, while the second part discusses the time interval for the back end of the rod to receive the message to stop moving. The solution given by the authors involves the compression of the bar and the time it takes for the wave to pass through the entire uncompressed length of the bar. However, there is a small correction to this solution that can be neglected.
Ghost Repeater
32
.[/B]
For a certain type of steel, stress is always proportional to strain with Young's modulus 20 x 10^10 N/m^2. The steel has density 7.86 x 10^3 kg/m^3. A rod 80.0 cm long, made of this steel, is fired at 12.0 m/s straight at a very hard wall.
a) The speed of a one-dimensional compressional wave moving along the rod is given by v = sqrt(Y/rho), where Y is Young's modulus for the rod and rho is the density of steel. Calculate this speed.
b) After the front end of the rod hits the wall and stops, the back end of the rod keeps moving as described by Newton's first law until it is stopped by excess pressure in a sound wave moving back through the rod. What time interval elapses before the back end of the rod receives the message that it should stop?
[/B]
This is a problem from Serway & Jewett's Physics for Scientists and Engineers textbook. Chapter 17, Problem 59.
I know the solution to the problem (from the solutions manual) but I have a question about the solution, because it doesn't make sense to me.
Part a) is straightforward of course. Just plug in the given data to the formula v = sqrt(Y/rho). But I am perplexed by part b).
The solution given to part b) by the authors is this: "The signal to stop passes between layers of atoms as a sound wave, reaching the back end of the bar in time interval Δt = L/v. As described by Newton's first law, the rearmost layer of steel has continued to move forward with its original speed v for this time, compressing the bar by ΔL = v_i *Δt."
This is the part I do not understand. To calculate the compression ΔL, the authors use the time it takes the wave to pass the entire uncompressed length of the bar. But isn't the whole point of the compression that the back end of the bar is moving toward the wave, at the same time as the wave moves toward the back end of the bar? So wouldn't it take the wave less time to meet the back end of the bar, since the two are approaching each other?
The way I tried to solve the problem was to treat the wave as moving from the front to the rear of the bar, and the back end of the bar as moving from the back end to the front, and the two would meet somewhere in the middle. But if the bar is compressing, then the wave can't take the whole time it would take to travel the uncompressed length to reach the compressed length, right?
Thanks for helping me clear up confusion.
This effect would make a very small correction (about 0.2% at 12 m/s projectile speed). I think you are expected to neglect it.
Well, that makes sense! Negligible is negligible, after all, ha ha. Thanks for the reply.
Related to Stress, Strain, and Sound in a Projectile Steel Rod
1. What is stress and strain in a projectile steel rod?
Stress is the amount of force applied to a material, while strain is the resulting deformation or change in shape of the material. In a projectile steel rod, stress and strain occur when the rod is subjected to external forces, such as when it is launched or impacted.
2. How do stress and strain affect the performance of a projectile steel rod?
High levels of stress and strain can cause the projectile steel rod to bend, deform, or even break. This can significantly impact the accuracy and effectiveness of the rod, as well as its durability and lifespan.
3. What factors contribute to stress and strain in a projectile steel rod?
Several factors can contribute to stress and strain in a projectile steel rod, including the material properties of the rod, the magnitude and direction of external forces, and the design and construction of the rod itself.
4. How can stress and strain be measured in a projectile steel rod?
Stress and strain can be measured using various techniques, such as strain gauges, load cells, and extensometers. These devices can provide quantitative data on the amount of stress and strain experienced by the projectile steel rod.
5. How does sound play a role in the behavior of a projectile steel rod?
Sound can be generated when a projectile steel rod is subjected to high levels of stress and strain. This is known as stress-induced noise and can provide valuable information about the structural integrity of the rod. Additionally, the speed of sound in the rod can also impact its performance and behavior.
