A Stress-strain; strain-displacement in 2-D; uniqueness
The discussion revolves around solving a 2-D planar problem involving stresses, strains, and displacements in a finite difference numerical solution for a square flat plate subjected to compressive loads. The stress matrix is symmetrical, leading to a situation where there are three knowns and four unknown displacement gradients, raising concerns about the uniqueness of the solution. The user seeks to impose an additional condition to resolve this issue, potentially using compatibility equations from literature. Boundary conditions are established, including fixed displacements on certain faces and stress conditions on others, to facilitate the simulation. The conversation highlights the importance of correctly defining boundary conditions to ensure a solvable and realistic model.
  • #51
Chestermiller said:
No. The solid would respond virtually instantaneously.
This all sounds very interesting. I'm a ChE, so this is the kind of thing I respond to.
OK. This helps. I don't think the pore pressures would be high enough to feed back into the solid mechanics.
Cool!
I'm still confused about the tensile loading. You mentioned that the solid would respond virtually instantaneously; are you implying that after this instantaneous response, the displacement would no longer be changing even though the constant load is still being applied?
The pore pressures are definitely pretty small. Though some of the materials do exhibit material loss that is expected due to exceeding a stress threshold.
By the way, I am a UM student.
  • #52
Sure.
You've been holding out on me. What department? Do you follow the football team? I've become obsessed with Michigan football. Do you ever go down and hang out at the athletic campus (just to catch a glimpse of the team and Jim)?
Likes pyroknife
  • #53
Chestermiller said:
Sure.
Hmm maybe that's where I'm confused. In thermophysics, if I apply a constant heat flux, that heat flux would continue to cause changes for the duration it is applied. I don't see why a constant compression load would not continue to cause displacement changes as long as it is being applied?
I'm from the aerospace department. Unfortunately, I don't watch football or any college sports, besides March Madness. I haven't been down to the stadium area since Jim was hired.
  • #54
Also, I was thinking, the equation of motion is a hyperbolic PDE. When you compress a rod, you sent some finite traveling in the direction of compression, which takes time to reach the other end of the rod, leading to changes/oscillations over time. So I don't understand how the response is instantaneous?
  • #55
I understand what you are asking. And, in an ideal theoretical system, what you are saying would prevail. But, the real world doesn't work like that, and the equations for an elasitic medium with mass/inertia is only an idealization. In the real world there are also dissipative forces at work, and, even though, in many situations, these force are small, they have a cumulative effect and allow the systems we are discussing to relatively rapidly reach static equilibrium.
When I said the response of the rod is instantaneous, what I really meant was that the response is virtually instantaneous. This is because the stress disturbance travels at the speed of sound (predicted by the dynamic equations you derived, with inertia included). So for a rod only a foot or two long, the response is virtually instantaneous.
You were talking about the transient temperature effect and comparing it to the transient stress effect. First of all, the transient heat transfer equations are parabolic, rather than hyperbolic. So the disturbance front is diffuse rather than sharp. Secondly, the speed at which the diffusive front progresses is much slower than the speed of sound, because the thermal diffusivity of the material is low. So, if you put a turkey in the oven, it takes hours for the thermal wave to reach the center of the turkey.
Here are two examples to help understand what I'm saying.
Consider a mass suspended on a spring, and you pull the mass downward, and then release it. Theoretically, the mass will oscillate up and down forever at the exact same amplitude, and the stresses and strains in the spring will continue varying forever. But, in the real world, we know that the amplitude of the oscillation will fairly rapidly decrease in time, and the mass will soon come to a new static equilibrium position. This is because of air drag acting on the mass which dissipates the kinetic energy.
Next, consider the kitchen chair I am sitting on right now. This chair is wooden, and has wooden legs. The legs of the chair are in compression, but there are no dynamic oscillations occurring in the legs of the chair. The stresses and strains in the chair legs are constant. This is due to the damping provided to the chair by the kitchen floor on one end, and my fat butt on the other end. This damping caused the oscillations to die out. So the chair and its legs are in static equilibrium. How long did it take to reach static equilibrium? The response to my sitting down was virtually instantaneous.
Likes pyroknife
  • #56
Thanks a lot for the examples. Very helpful.
The stuff I do is all computational, and so I lean more towards numerically solving the theoretical equations rather than making sense of it from a more practical aspect. This is just the base and to build on that would be to include/modify certain things in the modeling that would represent less than ideal things more representative of experiments or more realistic scenarios. There is another academic group doing similar work and in their recent paper they solved the steady state equation of motion, claiming that the structural equations reach equilibrium MUCH faster than the thermophysics, which is consistent what you said. I just didn't really understand it.
So this leads to my next question: Would it more representative of a real scenario to solve the transient equations WHILE accounting for phenomena such as damping, air resistance, etc... as opposed to solving a time-independent equation?
  • #57
The stuff I do is all computational, and so I lean more towards numerically solving the theoretical equations rather than making sense of it from a more practical aspect. This is just the base and to build on that would be to include/modify certain things in the modeling that would represent less than ideal things more representative of experiments or more realistic scenarios.There is another academic group doing similar work and in their recent paper they solved the steady state equation of motion, claiming that the structural equations reach equilibrium MUCH faster than the thermophysics, which is consistent what you said. I just didn't really understand it.
In analyzing a complicated system such as yours, you need to know the kinds of approximations you can make to get to your answer in a finite amount of time (i.e., real life time: you don't want to be at the U of M forever, right), while at the same time getting very accurate answers. In this case, you are considering the treatment you should use for the solid deformation mechanics part of your calculation. And you already know that another group has handled the solid mechanics by assuming quasi steady state.
I will call your attention to the fact that you have already made numerous approximations in other parts of your development without subjecting them to the intimate scrutiny you seem to be applying to the solid mechanics. In the aerodynamics, for example, are you solving the full time dependent Navier Stokes equations, including time dependence and turbulent stresses, or are you using boundary layer approximations? In the heat transfer, are you including conduction in the thickness direction and in the flow direction, or are you neglecting heat transfer in the flow direction? Are you including transient time dependence in the heat conduction equation? In applying Darcy's law, are you including time dependence (storativity), or are you assuming quasi steady state flow?
In handling the solid mechanics, you need to consider what your main objective is in this area. Are you analyzing the solid mechanics to include its coupling with the gas dynamics, or are you analyzing it just to determine the state of stress in the solid so you can evaluate strength and failure? It might even be better to use Strength of Materials approximations to the solid mechanics rather than your current Theory of Elasticity approach. So what I'm saying is that it might be advisable to simplify the solid mechanics even further, rather than to consider getting more complicated by including viscous damping explicitly in the equations and solution. What did the other group do? Theory of Elasticity or Strength of Materials? Using a strength of material approach would make life so much easier for you.
You have a system where you have air within the pores providing small scale viscous damping, and external air providing exterior damping. In addition, the shield material itself is probably not ideally elastic, and probably includes some inherent damping of its own (i.e., viscoelasticity). So worrying about going quasi static on the shield material doesn't make sense to me. And thinking about including damping explicitly in the equations really really doesn't make sense to me.
Where is your adviser in all this? Doesn't he/she help keep you pointed in the right direction by pointing out the kinds of accurate approximations you can/should make to simplify your analysis, while at the same time getting results of the desired accuracy?
  • #58
The code I'm currently working with doesn't solve for the external flow field, although that may be something for the future. This code only models the material itself. The full blown Navier Stokes equations are not solved for. The momentum equation is reduced to Darcy's law for the internal porous flow, which is a very simplified representation. However, we do have a validated hypersonics CFD code for solving the external flow field, which solves the solves the transient Navier Stokes equations accounting for vibrational nonequilibrium and chemical reactions. THere's one guy in my group working on adding turbulence models to the code. We're not the conventional continuum fluids group since almost everything we model is in a very high temperature regime (~10,000K), where nonequilibrium effects and chemical reactions need to be considered.The heat transfer equation (neglecting radiative heat transfer) that we solve for in the material is:
$$\frac{\partial (\rho e)}{\partial t} + \frac{\partial}{\partial x_i}(\phi_g\rho_g h_g u_{g_i}) - \kappa_{ij}\frac{\partial T}{\partial x_j} = 0$$
Removing that middle convection term (which accounts for energy transfer through convection of the internal gas) would yield the classical transient heat conduction equation. The materials we work with are typically anisotropic, so thermal conductivity is a 9 element tensor and accounts for the various directions.
In our modeling, Darcy's law is just the steady state form.
As far as I am aware of, there are 2 other groups trying to do thermophysics-structural modeling WITHIN the material. Both of them use the time-INDEPENDENT theory of elasticity. I think solving for the linear elastic equation is pretty simple? Although, I didn't really understand how the boundary conditions worked, but I think I have a much better idea now. Also, I'm trying to develop the software such that it can be extendable in the future for others who want to add more complex structural physics, but for me, I think my priority is just to get a stress and displacement field. The stress field is primarily for modeling the stress-dependency of the thermophysical material properties (for example conductivity in the above equation, porosity ##\phi## in the above equation) and the displacement field is primarily for moving the mesh.Also, my adviser isn't a structural person. The people providing my funding sort of steered me in this direction and these people are also not structural people. Plus, I have been working out of state this year. I am kind of on my own with the structural side.
  • #59
I have nothing to add, except to say simplify as much as possible. But please check that heat balance equation. It seems to be missing a derivative on the conduction term.
  • #60
Thank you for all the help.
And oops, it should be ##\frac{\partial}{\partial x_i}(\kappa _{i,j} \frac{\partial T}{\partial x_j})##
Likes Chestermiller
  • #61
I took a hiatus from looking at the structural problem for awhile and recently picked up again the past couple of weeks. I just realized what I think is a huge issue when solving the transient equation. The issue is these structural constants are HUGE (when I was previously working on this, I had largely neglected the constants). For example, steel's elastic modulus is about O(10^11), and its lame's constants are around ~O(10^8). In solving the transient equation, I have to consider stability issues. The max dt that I can use is essentially INVERSELY proportional to lame's constants, thus severely limiting my timestep size to the point that the computational time is impractical for the purpose of my code.
I could potentially approach this problem as steady state. However, temperature and slight pressure (also low pressure) charges really would suggest that this problem is transient.
