Stress tensor for non-Newtonian fluid
Suradi: In summary, for a non-Newtonian fluid, the stress tensor can be set up using the same equation as for a Newtonian fluid, but with the viscosity represented as a function of the 2nd invariant of the rate of deformation tensor. This equation can also give the same behavior as a power law fluid for simple shear flows. This means that for a symmetric pipe or rectangular duct, all other components of the stress tensor are equal to 0, except for the pressure and shear stress in the direction of flow.
ccrook
How does one setup the stress tensor for a non-Newtonian fluid? I know that for any fluid the normals should be the pressure and for a power law fluid the shear stress in the direction of flow is related by K(du/dy)^n. Does this mean that all other components are 0 for a symmetric pipe or rectangular duct?
For a purely viscous non-Newtonian fluid (not viscoelastic), you use exactly the same form of equation as for a Newtonian fluid (see Bird, Stewart, and Lightfoot), except that you represent the viscosity as a function of the 2nd invariant of the rate of deformation tensor. There is a form of this functionality that gives the same behavior as a power law fluid for simple shear flows.
Chet
FAQ: Stress tensor for non-Newtonian fluid
1. What is a stress tensor for non-Newtonian fluid?
A stress tensor for non-Newtonian fluid is a mathematical representation of the internal forces and stresses that exist within a non-Newtonian fluid. It describes how the fluid responds to applied forces, taking into account its non-Newtonian behavior.
2. How is a stress tensor for non-Newtonian fluid different from a stress tensor for Newtonian fluid?
The main difference between these two types of stress tensors is that a stress tensor for non-Newtonian fluid takes into account the non-linear relationship between stress and strain, whereas a stress tensor for Newtonian fluid assumes a linear relationship. This means that the stress tensor for non-Newtonian fluid is more complex and can vary depending on the type of non-Newtonian behavior exhibited by the fluid.
3. Why is the stress tensor important for studying non-Newtonian fluid?
The stress tensor is important for understanding the behavior of non-Newtonian fluids because it allows us to predict and analyze how these fluids will respond to external forces. This is crucial for many industrial and scientific applications, such as in the design of pipelines, pumps, and other fluid systems.
4. How is the stress tensor for non-Newtonian fluid calculated?
The stress tensor for non-Newtonian fluid is typically calculated using a constitutive equation, which relates the stress tensor to the strain tensor and other variables such as temperature, pressure, and shear rate. The specific form of the constitutive equation will depend on the type of non-Newtonian behavior exhibited by the fluid.
5. Can the stress tensor for non-Newtonian fluid change over time?
Yes, the stress tensor for non-Newtonian fluid can change over time, especially if the fluid is subject to varying external forces or if its properties (such as temperature or composition) change. This is why it is important to consider the time-dependent behavior of non-Newtonian fluids when studying their stress tensors.
