Stress Used in Lagrangian Equation for Solid Mechanics
In summary, Bathe outlines the use of the second Piola-Kirchhoff stress in the updated Lagrangian and total Lagrangian approaches, while others define these formulations in terms of the Kirchhoff or Cauchy stress in rate form. The reason for using the Kirchhoff or Cauchy stress in the governing equation is due to the need for a common frame of reference and the use of objective rates in dynamics. However, the PK2 stress is an objective measure and can be transformed through the pullback operator to be used in these formulations.
bcl
Bathe (reference below) outlines the updated Lagrangian (UL) and total Lagrangian (TL) approaches using the second Piola Kirchhoff (PK2) stress. Others (i.e., Ji, et al. and Abaqus) define the UL and TL formulations in terms of the Kirchhoff or the Cauchy stress in rate form. This form requires consideration of an objective rate (since the rate of the Kirchhoff or Cauchy stress is not objective).
Why even mess with the Kirchhoff or Cauchy stress in the governing equation? Why not just cast the equation as Bathe did in terms of the PK2 stress, since the rate of the PK2 stress is objective? If your constitutive equation is in terms of the Kirchhoff or Cauchy stress could you not just transform it through the pullback operator to cast it in terms of the PK2 stress?
Bathe, http://web.mit.edu/kjb/www/Books/FEP_2nd_Edition_4th_Printing.pdf )
Ji, et al., https://pdfs.semanticscholar.org/d915/d7bb83fb2b5a9f3d41f699751eb8ac557e3d.pdf
Abaqus 6.11 Theory Manual, Section 1.5.1, http://130.149.89.49:2080/v6.11/books/stm/default.htm
I had the same question when I was first introduced to the UL approach and objective rates...
In a high-fidelity finite element analysis (e.x. a mesh of continuum elements in ADINA or ABAQUS), two things need to happen:
1) In order for the elements to talk to each other, they need a common frame of reference.
2) In order to do dynamics, the continuum mechanics must be done in rate form.
Regarding 1, the common frame of reference that makes the most sense is the global coordinate system. Most call this the "spatial" reference frame, but I'm not sure what terminology Bathe uses. In the spatial reference frame, we ought to see a change of the stress tensor for any element that undergoes a rotation. Since the PK2 stress tensor (and its work-conjugate Green-Lagrange strain) is defined in the "material" coordinate system, it does not change at all under rigid body rotations (Bathe says "invariant"). There's so much emphasis on the Cauchy stress (and its work-conjugate Almansi strain) because it's defined in the spatial reference frame.
Regarding 2, the time derivative of the Cauchy stress is really important for time-stepping, but since it is not work-conjugate with anything (e.x. the time rate of change of the Green-Lagrange strain, nor the velocity strain tensor, nor the Cauchy stress itself), you have to instead use an "objective" rate (e.x. Jaumann rate). The objective rate should be work-conjugate with the velocity strain tensor. The computer simulation will update the "objective" stress tensor for that particular element, for that particular time-step. The "objective" stress tensors lack physical meaning, but then the FEA will use them to find the Cauchy stresses, and perform equilibrium for the entire FEA, then do it all over again for the next time-step.
Related to Stress Used in Lagrangian Equation for Solid Mechanics
1. What is the Lagrangian equation for solid mechanics?
The Lagrangian equation for solid mechanics is a mathematical equation that describes the motion of a solid object based on its position, velocity, and acceleration. It is derived from the principle of least action and is commonly used in engineering and physics to analyze the behavior of materials under stress.
2. How is stress incorporated into the Lagrangian equation for solid mechanics?
In the Lagrangian equation for solid mechanics, stress is incorporated through the use of strain energy density, which is a measure of the internal work done by the applied stress on the material. This strain energy density is then used to calculate the potential energy of the system, which is a key component of the Lagrangian equation.
3. Why is stress used in the Lagrangian equation for solid mechanics?
Stress is used in the Lagrangian equation for solid mechanics because it is a crucial factor in determining the behavior of materials under external forces. By incorporating stress into the equation, we can accurately predict the deformation and response of a solid object to applied loads, making it a valuable tool in engineering design and analysis.
4. What types of materials can the Lagrangian equation for solid mechanics be applied to?
The Lagrangian equation for solid mechanics can be applied to a wide range of materials, including metals, polymers, and composites. It is also applicable to both elastic and plastic materials, making it a versatile tool for studying the behavior of various materials under different stress conditions.
5. Are there any limitations to using the Lagrangian equation for solid mechanics?
While the Lagrangian equation for solid mechanics is a powerful and widely used tool, it does have some limitations. It assumes small displacements and linear elastic behavior, which may not be accurate for all materials. Additionally, it may not be suitable for complex systems or situations where there is significant energy dissipation.
