Stretched spring and change in mass
In summary, the conversation discusses the concept of mass increase when a spring is stretched. It is explained that mass is only conserved for isolated systems and that stretching a spring does not increase its mass significantly. The equation ##E=mc^2## is used to show the relationship between energy and mass, with the role of ##c## being a unit conversion factor. The importance of verifying equations through experimentation is emphasized.
Mohammed Shoaib
I came across with this question in my work.
A stretched spring has greater energy and therefore greater mass than an unstretched spring. What's the mass increase when you stretch a spring with 500N/m by 40cm?
My question is How mass can increase with stretching of the spring?
As per fundamental physics mass is conserved. I am confused. Kindly help.
Thanks in advance.
The relationship between energy, mass, and momentum is ##m^2 c^2=E^2/c^2-p^2##
Mass is only conserved for isolated systems. A spring cannot be stretched if it is isolated.
Thanks for reply.
But sorry
I did not get that?
Why did you use relativistic energy momentum for a mass - spring mass system.
Because you ask how mass increases if Energy increases . Newton cannot answer that question because mass and energy are separately conserved in classical mechanics .
Because it is the only theory where this claim is true:
If you did not intend to discuss relativity then you can simply neglect the whole idea as an insignificant relativistic effect.
By being stretched the spring gains potential energy, then according to ##E=mc^2## it's mass increases.
How can we relate the factor c speed of light in the E=mc2 and say this equation explains the increase in mass of a stretched spring. kindly explain the role of c here.
It's the unit conversion factor between mass and energy. You can set it to 1 by an appropriate choice of units if you like.
It is just a unit conversion factor. The SI unit system was started before relativity was understood, so whenever you are looking at relativistic quantities you will see factors of c used to convert SI units.
An analogy would be an ancient sailor measuring vertical distances in fathoms and horizontal distances in nautical miles. You would wind up with conversion factors any time you had a formula that includes both a horizontal distance and a vertical distance.
Similarly, energy and momentum are the timelike direction and the spacelike direction of the same thing. They could be measured in the same units, and when you do not then you get factors of c in the relationship ## m^2 c^2 = E^2/c^2-p^2##
Can you first show us that you know how to solve this problem?
What's the mass increase when you stretch a spring with [a spring constant of] 500 N/m by 40 cm?
That is, calculate the amount the energy in joules, and then convert it to a mass in kilograms. Once you do that it may become obvious to you why it's safe to ignore the contribution made to the spring's mass by stretching the spring.
It's really necessary that you first do this so that you'll have the context needed to understand our answer to your question.
Potential energy U=1/2kx2 = 40J and m from e=mc2 gives m=4.44x10^-16kg.
Thanks for support.
Your calculation shows that the mass increase is ridiculously small, several orders of magnitude smaller than the mass of an single electron.
The role of ##c## in ##E=mc^2## doesn't explain the increase in mass any more than the role of ##k## in ##E=\frac{1}{2}kx^2## explains the increase in energy. There are derivations you can study that will explain the validity of equations such as ##E=\frac{1}{2}kx^2## and ##E=mc^2##, and it's ultimately up to people to verify by experiment that these equations are valid. All of that is done before they appear in textbooks and we are asked to learn them.
It is more like the mass of a small bacterium. Still very small, but much larger than an electron or even a proton.
I agree with the remainder of your post.
Oops! Of course you're right. It's several orders of magnitude LARGER than an electron's mass. :frown:
Related to Stretched spring and change in mass
1. How does the mass of an object affect the stretch of a spring?
The mass of an object does not directly affect the stretch of a spring. However, the weight of an object (mass x gravity) does affect the stretch of a spring. The heavier the object, the greater the force acting on the spring and therefore, the more the spring will stretch.
2. What is the relationship between the stretch of a spring and the mass placed on it?
The stretch of a spring is directly proportional to the mass placed on it. This means that as the mass increases, the stretch of the spring will also increase. This relationship is known as Hooke's Law.
3. Can the spring constant change when the mass of an object is altered?
No, the spring constant is a property of the spring itself and does not change when the mass of an object is altered. The spring constant is a measure of the stiffness of the spring and remains constant regardless of the mass placed on it.
4. How can the stretch of a spring be measured?
The stretch of a spring can be measured by calculating the change in length of the spring from its original, unstretched state. This can be done by using a ruler or measuring tape to measure the length of the spring before and after the mass is placed on it.
5. Does the length of the spring affect the stretch when the mass is changed?
Yes, the length of the spring can affect the stretch when the mass is changed. A longer spring will generally stretch more than a shorter spring when the same mass is placed on it. This is because a longer spring has a greater surface area, which results in a greater force being applied to the spring and causing it to stretch more.
