String number density - does it make sense?
  • Thread starter frank_k_sheldon@yahoo.co.uk
  • Tags
    Density String
In summary, on a blog, a user asks if it makes sense to talk about the number of strings in a volume of space. A moderator notes that this is possible in a perturbative treatment, but the quantum number is problematic and not conserved. The number of strings would depend on the energy, and at high energies, the number would be higher. It is unclear what the number would be at 1 eV in flat empty space.
On a blog I came across a strange question:
"Does it make sense to speak about the number of
strings found in a volume of space?"
Could anybody comment on this? I would be
interested if one has to imagine string theory
as filling all of space with strings Or branes),
or whether this is the wrong visualization.
Frank
[Moderator's note: one can construct the "number of strings" operator in a
perturbative treatment of string theory - much like you can talk about
the number of particles and/or the level of the harmonic oscillator.
However, both in quantum field theory and string theory, this quantum
number is a bit problematic. It is certainly not conserved. In QFT, it
depends on the energy scale at which you understand the system - because
with a high enough scale, you find very many gluons inside the proton,
to say an example. The "number of particles" behaves strangely when
you include interactions. The latter statement is also true in string
theory. The real physical objects at nonzero coupling are not just the
"bare 1 string" that you know from g=0. LM]
I was always looking for answers to the comment, but saw the
moderator's note only today.
To continue on the QCD analogy, the number of strings would
thus depend on the energy. I suppose this also correct for empty space.
Thus the number of strings in empty
space will depend on the energy. (Correct?)
If this is so, can we give numbers?
I suppose that at 10^19 GeV (Planck energy), the number is maybe one
string per mm^3 (or probably one string for any volume whatsoever),
whereas at 1 eV it is very high. Is this correct?
And if so, can one give an estimate for the number of strings at 1eV
in flat empty space? (Or does one need to specify some other
condition?)
That is really an interesting issue!
Frank
I can comment on this question. The concept of string number density is a valid and useful concept in string theory. In fact, it is an important part of the perturbative treatment of string theory, similar to how we can talk about the number of particles in quantum field theory.
However, it is important to note that this quantum number is not conserved and can behave strangely when interactions are included. This is true for both quantum field theory and string theory. In string theory, the physical objects at non-zero coupling are not just the "bare 1 string" that we know from a g=0. This means that the visualization of strings filling all of space may not be accurate.
In string theory, the strings are considered to be one-dimensional objects that vibrate in a higher-dimensional space-time. So it may be more accurate to think of them as occupying a small region or volume within that higher-dimensional space. This means that the concept of string number density may not be applicable to the entire space, but rather to a specific region within it.
Overall, while the concept of string number density may make sense in certain contexts, it may not be appropriate to apply it to the entire volume of space. As with any scientific theory, it is important to carefully consider the assumptions and limitations of the concepts being used.
Related to String number density - does it make sense?
1. What is string number density?
String number density refers to the number of strings (or strands) that make up a certain length of material. It is a measure of the concentration of strings in a given space.
2. How is string number density measured?
String number density is typically measured by counting the number of strings in a known volume of material and then calculating the density using the formula: density = mass/volume. The mass of a single string is usually determined beforehand by weighing a known length of string.
3. What is the significance of string number density?
String number density is important in understanding the properties and behavior of materials made up of strings, such as polymers, DNA, and spider silk. It can also be used to determine the strength and durability of these materials.
4. How does string number density affect material properties?
The higher the string number density, the more closely packed the strings are, which can make the material stronger and more resistant to stretching. However, if the density is too high, it can also make the material more brittle and prone to breaking under stress.
5. Can string number density be changed?
Yes, string number density can be changed by altering the length of the material or by adding or removing strings. However, this may also affect the material's properties, so it is important to carefully consider the desired density for a specific application.
  • Beyond the Standard Models
