Is the Strong Force Really Stronger Than the Electromagnetic Force?
In summary, the strong force is the strongest force, with the electromagnetic force being the second strongest. The idea of equilibrium between the two forces is a misunderstanding, as the protons in a nucleus are in stable or metastable states. The range of the electromagnetic force is infinite, while the strong force is very short range and only a handful of nucleons can interact via it. The strong nuclear force is overwhelming the electromagnetic force until dozens of protons are gathered together. The average positions of the nucleons must be stationary, but they must also be in motion with respect to each other due to the Uncertainty Principle. While electromagnetism can have an effect on nuclei, it is not the primary force at play.
PhDnotForMe
56
So I am aware that the strong force is the strongest force with the electromagnetic force being the second strongest force. I am wondering how we go about the process of deciding which force is stronger.
I am visualizing a helium nucleus; two protons, two neutrons. The two protons are pushing away from each other with the electric repulsive force, while there is a strong force connection between each of the hadrons. It seems to me that because the protons are neither moving away nor moving towards each other, the electromagnetic force and strong force are in equilibrium. If this is true how can it be claimed the strong force is stronger than the electromagnetic force. I believe I read somewhere that it is 137 times stronger. Would love an explanation about this!
does this help ...
note the distances over which they act
Likes PhDnotForMe and anorlunda
There's a misunderstanding here. The protons don't move towards or away from each other because they are in stable or metastable states. Much like how electrons exist in atomic orbitals and neither move away from or towards the atom. They would certainly move closer in towards the nucleus if they could, but such a lower energy state either doesn't exist or is already filled by other electrons. The laws of nature apparently forbid fermions from occupying identical states, and it is this that keeps both protons from moving closer together as well.
One thing to notice is that the repulsive force from protons on each other increases as you add more and more protons, and this happens without limit because the range of the EM force is infinite. However, the strong nuclear force (the residual part of the color force to be more specific) is very short range, and only a handful of nucleons will attract each other via it. So it must be the case that the strong nuclear force is overwhelming the EM force until you gather together dozens and dozens of protons. Otherwise we would see stable light nuclei falling apart as soon as you add a couple of protons together.
Likes lowlize, PhDnotForMe and davenn
The average positions must be stationary, otherwise the system would fall apart, but equally the nucleons must be in motion with respect to each other, otherwise one would have a fixed position is a frame of reference defined by the others and hence zero momentum in that frame, which violates the Uncertainty Principle. If we assume an underlying Lagrangian (which the standard model has) and some form of function for the potential energy, then the viral theorem defines a relationship between kinetic and potential energies for bound states. For those interested in oddities, the first theoretical attempt at predicting the nuclear energy relied on electromagnetism, and it got the energies fairly well up to oxygen (Volochine, F. E. 1925. C. R. des Séances de la Société Polonaise de Physique, Fasc V.: 61 – 73.) Additionally, he correctly predicted the spin magnetism of the yet to be discovered neutron. While this was wrong because he needed the proton and neutron to be about 6-7 times smaller than they actually are, this work showed that electromagnetism can have more effect than most think. Since this is not the place for speculative theories, one cannot go further here, but it may not be totally impossible to go further.
Likes PhDnotForMe
FAQ: Is the Strong Force Really Stronger Than the Electromagnetic Force?
What is the difference between the strong force and electromagnetic force?
The strong force is one of the four fundamental forces of nature and is responsible for holding together the nucleus of an atom. It is much stronger than the electromagnetic force, which is responsible for interactions between charged particles.
How do the strong force and electromagnetic force interact with each other?
The strong force and electromagnetic force do not directly interact with each other. The strong force only acts on particles within the nucleus, while the electromagnetic force acts on all charged particles, including those outside the nucleus.
Which force is responsible for holding atoms together?
The strong force is responsible for holding the nucleus of an atom together, while the electromagnetic force is responsible for holding the electrons in orbit around the nucleus.
Can the strong force and electromagnetic force be unified?
Currently, scientists have not been able to unify the strong force and electromagnetic force into one theory. They are described by separate theories, but some theories, such as string theory, attempt to unify all four fundamental forces.
What role do the strong force and electromagnetic force play in the universe?
The strong force and electromagnetic force are essential for the existence of matter in the universe. The strong force holds together the protons and neutrons in the nucleus, while the electromagnetic force allows for chemical reactions and the formation of molecules. Without these forces, the universe would look very different, if it existed at all.
