Stronger Goldbach-related conjecture
  • Thread starter rokirovka
  • Tags
    Conjecture
In summary, the conversation discusses the definition of gap(n) for a positive integer n>1 and its connection to the Goldbach Conjecture. The speaker also presents a conjecture that the maximum value of gap(n)/n is gap(22)/22 = .40909... for certain primes p and q. They suggest that a weaker version of the conjecture could be more useful in terms of bounding the solution space and potentially proving the stronger version.
rokirovka
For any positive integer n>1, define gap(n) as
gap(n) = |n-p| = |n-q| for p,q the two primes closest to n such that p+q = 2n.
The Goldbach Conjecture is equivalent to the existence of p and q, and thus the existence of gap(n), for all n>1. (Or all n>2 if p and q are required to be odd primes, which does not affect the substance of the conjecture.)
But I make the following conjecture, which is stronger than the mere existence of gap(n) for all n>1:
For all n>1, the maximum value of gap(n)/n is gap(22)/22 = 9/22 = .40909... (for primes p=13 and q=31).
Other high values of gap(n)/n are
gap(8)/8 = 3/8 = .375 (p=5, q=11)
gap(46)/46 = 15/46 = .326... (p=31, q=61)
gap(28)/28 = 9/28 = .321... (p=19, q=37)
gap(32)/32 = 9/32 = .28125 (p=23, q=41)
gap(58)/58 = 15/58 = .259... (p=43, q=73)
gap(4)/4 = 1/4 = .25 (p=3, q=5)
Other n for which gap(n)/n > .2 include [in descending order of gap(n)/n] n=49, 25, 38, 146 [gap(146)=33 for p=113, q=179], 9, 68, 55, 14, 24, 74.
Hello, rokirovka,
I don't know much about the subject, but I would imagine that a weaker version of your conjecture, like
If gap(n) exists, then it is not bigger than 9n/22​
would be more useful, in terms of bounding the solution space.
And surely it is much more likely that a large gap(n)/n exists for some n, than it is that gap(n) does not exist at all for some n.
The former is a lack of primes p,q that sum to 2n within a certain large range from about 3n/5 to 7n/5. The latter is a lack of primes p,q that sum to 2n within the entire range from 1 to 2n.
So if your weaker version of the conjecture is true, that would imply with overwhelming likelihood the truth of the stronger version as well. Of course "overwhelming likelihood" is not an acceptable form of mathematical proof. But proving your weaker version could be the right way to begin to tackle the problem.
FAQ: Stronger Goldbach-related conjecture
Can you explain what the Stronger Goldbach-related conjecture is?
The Stronger Goldbach-related conjecture, also known as the extended Goldbach conjecture, states that every even integer greater than 5 can be written as the sum of three prime numbers. This is an extension of the original Goldbach conjecture, which states that every even integer greater than 2 can be written as the sum of two prime numbers.
Has the Stronger Goldbach-related conjecture been proven?
No, the Stronger Goldbach-related conjecture has not been proven. It remains an unsolved problem in mathematics and is considered to be one of the most challenging problems in number theory.
What progress has been made towards proving the Stronger Goldbach-related conjecture?
Several mathematicians have made significant progress towards proving the Stronger Goldbach-related conjecture. In 2013, Harald Helfgott published a paper in which he proved that every odd integer greater than 5 can be written as the sum of three prime numbers. This was a major breakthrough, but the conjecture remains unsolved for even integers.
Are there any counterexamples or cases where the Stronger Goldbach-related conjecture does not hold?
No, there are no known counterexamples or cases where the Stronger Goldbach-related conjecture does not hold. However, this does not prove that the conjecture is true for all even integers, as it is impossible to check every possible case.
Why is proving the Stronger Goldbach-related conjecture important?
The Stronger Goldbach-related conjecture is important because it has been widely studied and has connections to other areas of mathematics, such as additive number theory and sieve theory. Additionally, solving this conjecture would provide a deeper understanding of the distribution of prime numbers and could potentially lead to new techniques and insights in mathematics.
