Structural engineering - sizing a beam using loads/span
In summary, the loads on a beam can be determined by considering the weight of the structure it is supporting, the weight of any objects or people on the structure, and additional forces like wind, snow, or seismic activity. The span of a beam refers to the distance between the supports, and is important in determining the size and strength of the beam needed. The size of a beam is calculated by considering the loads and span, and using mathematical equations to determine the bending moment and shear forces. Dead load refers to the weight of the structure itself, while live load refers to the weight of objects or people on the structure. Common materials used for beams in structural engineering include wood, steel, concrete, and composite materials, with the choice depending on
steve321
25
Hi!
I'm looking for information on how one would size a wide-flange beam knowing the live/dead loads and the span required
i can't seem to find any calculations for this sort of thing!
beam is not composite with floor
Span/depth ratio will be roughly 10 for a heavy load, 20 for a light load, 15 for a medium load. Then you have to check stresses and deflection for a given choice of specific beam.
FAQ: Structural engineering - sizing a beam using loads/span
1. How do I determine the loads on a beam?
The loads on a beam can be determined by considering the weight of the structure it is supporting, the weight of any objects or people that will be on the structure, and any additional forces such as wind, snow, or seismic activity. These loads can be calculated using mathematical equations and considering the specific requirements of the structure.
2. What is the span of a beam?
The span of a beam refers to the distance between the supports that the beam is resting on. This distance is an important factor in determining the size and strength of the beam needed to support the desired loads.
3. How do I calculate the size of a beam?
The size of a beam is determined by considering the loads it will need to support and the span of the beam. This information is then used to calculate the bending moment and shear forces on the beam, which can then be used to determine the appropriate size and type of beam needed to meet the structural requirements.
4. What is the difference between dead load and live load?
Dead load refers to the weight of the structure itself, including the beams, columns, walls, and other materials. Live load refers to the weight of objects or people that will be on the structure, such as furniture, appliances, and people. Both dead load and live load are important factors in determining the loads on a beam.
5. What are some common materials used for beams in structural engineering?
Common materials used for beams in structural engineering include wood, steel, concrete, and composite materials. The choice of material depends on factors such as the desired strength and stiffness, cost, availability, and environmental considerations.
