[Structural Mechanics] Conceptual Questions - Mechanisms & Plastic Analysis
In summary: Expert SummarizerIn summary, the given structure is a cantilever beam with a physical hinge in the middle. To determine the failure mechanism and plastic moment, we can use the upper bound or lower bound theorem for plastic analysis. In this case, the failure mechanism will occur at the hinge and the plastic moment will be equal to 3/2 times the moment applied at the hinge, according to Euler-Bernoulli beam theory.
MarleyDH
Determine the failure mechanism and plastic moment for the following structure, using either the upper bound or lower bound theorem for plastic analysis.
(There is a physical hinge in the middle of the structure)
Internal Work = External Work
Euler-Bernoulli Beam Theory
The structure is a mechanism from the word go. My question is the conceptual question; namely, why?
Solving the structure via equilibrium confirms the problem, but its the concept that I can not grasp.
Any help would be appreciated.
Thank you for your question. From the given picture, it appears that the structure is a cantilever beam with a physical hinge in the middle. In order to determine the failure mechanism and plastic moment, we can use the upper bound or lower bound theorem for plastic analysis.
The upper bound theorem states that the plastic moment is equal to the external moment that can be applied to the structure without causing failure. This means that if we apply a moment greater than the plastic moment, the structure will fail. On the other hand, the lower bound theorem states that the plastic moment is equal to the internal moment that can be developed in the structure without causing failure. This means that if the internal moment in the structure is greater than the plastic moment, the structure will fail.
In this case, since the structure has a physical hinge in the middle, it can be assumed that the failure mechanism will occur at this hinge. This means that the plastic moment will be equal to the moment applied at the hinge. To determine the plastic moment, we can use Euler-Bernoulli beam theory, which states that the maximum moment in a cantilever beam occurs at the fixed end and is equal to 3/2 times the applied moment.
Therefore, the failure mechanism for this structure will be the physical hinge in the middle, and the plastic moment will be equal to 3/2 times the moment applied at the hinge. I hope this helps to clarify the concept for you. If you have any further questions, please don't hesitate to ask.
Related to [Structural Mechanics] Conceptual Questions - Mechanisms & Plastic Analysis
1. What is the difference between a mechanism and a structure?
A mechanism is a system of interconnected parts that work together to perform a specific function, while a structure is a system of connected elements that support loads and resist forces. Mechanisms are typically designed to move or transmit forces, while structures are designed to remain in a stable position.
2. How does plastic analysis differ from elastic analysis?
Plastic analysis is a method used to analyze the behavior of structures beyond their elastic limit, where the material begins to permanently deform. In contrast, elastic analysis only considers the behavior of a structure within its elastic limit, where the material returns to its original shape after being subjected to external loads.
3. What is the significance of the plastic hinge in plastic analysis?
The plastic hinge is a hypothetical point in a structure where plastic deformation occurs. It is an important concept in plastic analysis because it allows us to simplify the analysis of a complex structure into simpler, idealized sections. Plastic hinges are also used to determine the ultimate load carrying capacity of a structure.
4. How do you determine the plastic moment capacity of a beam?
The plastic moment capacity of a beam is the moment at which the beam reaches its ultimate strength and begins to experience plastic deformation. This can be calculated using the yield stress of the material, the cross-sectional area of the beam, and the distance from the neutral axis to the extreme fiber. The plastic moment capacity is also affected by the shape and size of the cross-section of the beam.
5. Can plastic analysis be applied to all types of structures?
No, plastic analysis is typically only used for statically indeterminate structures, where the number of unknown forces and reactions is greater than the number of equilibrium equations. It is not applicable to statically determinate structures, as the behavior of these structures can be accurately determined using elastic analysis methods.
