Structure R^k and midpoints of vectors
In summary, the conversation discusses a self-study of mathematical analysis and a problem set involving proving a theorem with different cases. The speaker is struggling with finding a clean and neat proof using definitions and theorems, but has made progress on parts b and c. They have also considered the geometric representation of the problem in 3-space and the plane. The suggestion is made to use a more user-friendly book for self-study.
SiddharthM
176
First this is NOT a homework problem. I am undertaking a self-study of mathematical analysis by following Rudin's Principles of Mathematical analysis. I have done a course in analysis before but this is a high-powered review of sorts.
So I'm currently on the first chapter's problem set and I've gotten stuck on problem 16, which asks:
Let x,y in R^k, k>/=3 (at least 3-space), norm[x-y] = d>0 prove:
a)If 2r>d There are infinitely many z in R^k s.t. norm[z-y]=norm[z-x]=r
b)If 2r=d there is exactly one such z.
c)If 2r<d there are no such z.
That is the question as stated, to clarify the norm I speak of is the tradition euclidean k-space norm (i.e. root of sum of squares of components).
Part a) is the one I've made the least progress on, b) I'm half done and c) is a simple proof by contradiction using the triangle inequality.
Geometrically (for part a)) consider the line between x and y, there is a perpindicular plane at the midpoint (x+y)/2 (perpendicular to the line connecting x and y) and the set of infinite z that a) asks for is the circle of radius (r^2 - (d/2)^2)^(1/2) which is nonzero b/c of the hypothesis lying on the tangent plane centered at the midpoint (x+y)/2. The thing is, I presume rudin wants me to construct a general z that admits infinitely vectors, but I've found this very difficult to do using the definitions and theorems given in the chapter. Any ideas?
Part b) the only such z is x+y=2 but I can't for the life of me prove that it is the ONLY solution with rigour.
Help would be much appreciated.
Cheers,
Siddharth M.
PS: obviously the problem I'm having is providing a clean and neat proof strictly using definitions and theorems as is required of an analyst but such a solution has thus far escaped me.
as you know, my advice is to choose some more user friendly book, especially for self study.
have you drawn a picture in the plane? i.e. for the forbidden k = 2 case?
It's not so much self-study as much as it is a high-powered review. I'm familiar with the theorems in the first 7 chapters, also I've taken a course in measure theory that was significantly more challenging. That being said Rudin is perfect for honing my problem-solving skills while reviewing the essential theorems of the theory.
I've "drawn" it in 3-space - it's actually fairly easy to picture.
in the plane the assertions are the same except 2r>d means there are two solutions, on the line you never get a solution unless 2r=d, in which case only the midpoint suffices.
The only way I can see to do this is using a constructive proof, but my methods have gotten too messy. There needs to be a slicker way of going about this theorem.
FAQ: Structure R^k and midpoints of vectors
What is the definition of Structure R^k?
Structure R^k refers to a mathematical concept that represents a k-dimensional space, where k is any positive integer. It is typically used to describe geometric figures and vector spaces.
How do you calculate the midpoint of two vectors?
The midpoint of two vectors can be calculated by adding the two vectors together and then dividing the sum by 2. This will give the average of the two vectors and represent the midpoint between them.
What is the significance of midpoints in vectors?
Midpoints in vectors are important because they divide a vector into two equal parts. They can also be used to find the center of a line segment or the midpoint of a polygon.
Can you have a midpoint in a one-dimensional vector?
No, a one-dimensional vector only has one point and therefore does not have a midpoint. Midpoints are only applicable in two or more dimensional vectors.
How do you find the coordinates of a midpoint in a three-dimensional vector?
To find the coordinates of a midpoint in a three-dimensional vector, you can use the formula (x1 + x2)/2, (y1 + y2)/2, (z1 + z2)/2, where x1, y1, and z1 are the coordinates of the first vector and x2, y2, and z2 are the coordinates of the second vector.
