Dale
Mentor
- 36,474
- 15,225
Sure I did. In 66 I showed that experience does not relate to the reference frame for what you called raw experience. Then in 71 I showed that for your calculated experience it applies to all reference frames equally.whatif said:Your have claimed it but I do not think you have shown it.
As I showed above, raw experience relates to the past light cone rather than your reference frame, and your calculated experience relates equally to any frame of reference.whatif said:How does experience relate to frames of reference?
The question was not written off, it was answered. You just didn’t like the answer.whatif said:It is all very to say the any chosen frame is valid but so is the question and to write the question off because of the way it is handled by geometry and analogues with space alone (which seems to me what you are effectively doing) might be presumptuous.
Frankly, it is somewhat irritating to me to provide a substantive answer to your question, have you not respond to the substance of the answer, and then
1) claim that I hadn’t shown what anyone can read and see that I did show
2) say that I “wrote off” a question which I in fact had answered
3) call me presumptuous for the non-existent write off
Really, do you think that is acceptable? If you don’t like or don’t agree with the answer that is one thing, but to claim that you were dismissed or not answered is clearly untrue. Perhaps you were overwhelmed with the volume of responses and could not make a substantive response to mine. That is fine and understandable, but it is also the exact opposite of writing the question off.
Ok, so now you have introduced a third meaning of experience. The time that would be related to someone’s experience is called proper time. Proper time is invariant so all frames agree on it. It does not single out any frame as special.whatif said:one has had more experience, so to speak, than the other, if time is a measure of experience.
So now we have three meanings of “experience”. Raw experience depends on the past light cone. Calculated experience could equally apply to any frame. Proper time experience is frame invariant. So none of the three meanings of experience uniquely implies the observer’s rest frame.
That is correct. This quantity is called proper time and it is invariant. All reference frames agree on it. Proper time is the Minkowski invariant geometric quantity that is analogous to the Euclidean invariant geometric quantity of length. Your “as I see it” comment actually indicates that you are not too far away from the geometric analogy. You just need to make the connection between your comment above and the analogy.whatif said:the experience of time is the same for that person and the rate of ticks of perfect clocks in a persons pocket is does not vary for that person; as I see it
