MHB Struggling with Exercise 2.1.40 in Sohrab's Basic Real Analysis?
  • Thread starter Thread starter Math Amateur
    Density Exercise
Math Amateur
MHB
I am reading Houshang H. Sohrab's book: "Basic Real Analysis" (Second Edition).
I am focused on Chapter 2: Sequences and Series of Real Numbers ... ...
I need help with Corollary 2.1.39/Exercise 2.1.40 ...
Corollary 2.1.39/Exercise 2.1.40 reads as follows:https://www.physicsforums.com/attachments/7090I have not been able to make a meaningful start on Exercise 2.1.40 despite Sohrab's hint ...
Can someone please help with Exercise 2.1.40 ... ?
Peter
The main theorem, Theorem 2.1.38, to which this is a corollary, says that between any two real numbers, there is a rational number. Applying that to the two numbers \frac{x}{\sqrt{2}} and \frac{y}{\sqrt{2}}, there exist a rational number, s, such that \frac{x}{\sqrt{2}}< s< \frac{y}{\sqrt{2}}. Multiply each part by \sqrt{2}: x< s\sqrt{2}< y.
To finish, show that any (non-zero) rational number times an irrational number is irrational.
Thanks for the help, HallsofIvy ...
As you say, we need to show that any (non-zero) rational number times an irrational number results in an irrational number.
So let $$a \in \mathbb{Q}$$ and $$b \in \mathbb{R}$$ \ $$\mathbb{Q}$$ be any non-zero numbers ...
Consider $$a \cdot b = c$$ for some real number $$c $$ ...Now ... assume that $$c$$ is rational ... then we have ...
$$a \cdot b = c \Longrightarrow b = a^{ -1} \cdot c$$
But ... given that $$a$$ is rational, we have that $$a^{ -1 }$$ is rational ... ...
... and it follows, under the assumption that $$c$$ is rational, that $$a^{ -1} \cdot c$$ is rational ...
But then $$b$$ must be rational ... Contradiction! ...So $$c$$ must be irrational ... that is, the product of a rational number and an irrational number is an irrational number ...Is that correct?
Peter
Yes, assuming that you have already proved that the product of two rational numbers is rational, that is a valid proof.
Thanks for your help, HallsofIvy ...
Definitely assumed that product f two rationals is rational ... thanks for pointing that out ...
Peter
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
