Struggling With Plasma Physics Question
  • Thread starter Thread starter fizicksiscool
    Plasma physics
The discussion revolves around solving a plasma physics problem involving equations of motion and current density. The user struggles with incorporating the term δn and understanding how ε0 relates to the plasma frequency ωp. They derive expressions for current density and time derivatives but encounter issues with extra factors of ε0 and the requirement for α± to be constants rather than tensors. The conversation includes suggestions for using vector analysis identities and references to external notes on electromagnetic waves in plasma, ultimately leading to a verification of the user's derivation, which confirms the presence of ε0 in the final expression. The user is left questioning the necessity of dimensional constants in their solution.
fizicksiscool
The Equation of motion is: ##m\frac{d\textbf{v}}{dt} = -e(\textbf{E}(\textbf{r} ,t) + \textbf{v} \times \textbf{B}_{ext})##
Where ##\textbf{B}_{ext}## is a constant in the +z direction.
##E = \begin{bmatrix}
E_x \\
E_ y \\
0 \\
\end{bmatrix} =
\begin{bmatrix}
cos(k_{\pm}z - \omega t)\\
\pm sin(k_{\pm}z - \omega t) \\
0 \\
\end{bmatrix}##
The number density of mobile electrons is ##n(r, t) = n_0 + \delta n(r, t)##
There is also an immobile background charge density ## \rho = +en_0##
Assuming that such a wave exits, Show that a possible solution of the equation of motion results in E creating a current j obeying:
##\frac{d\textbf{j}}{dt} = \alpha_{\pm}\textbf{E}##
Find the constants ##\alpha_{\pm}## in terms of ##\omega##, ##\omega_c = \frac{eB_{ext}}{m}##, and ##\omega_p^2 = \frac{n_0e^2}{m\epsilon_0}##
The Maxwell Equations:
##\nabla \times B = \mu_0 j +\frac{1}{c^2}\frac{\partial E}{\partial t}##
##\nabla \times E = -\frac{\partial B}{\partial t}##
##\nabla \cdot E = \frac{\rho}{\epsilon_0}##
##\nabla \cdot B = 0##
and
##\textbf{j} = -ne\textbf{v}##
First, assuming, ##v \alpha e^{i(k{\pm}z - \omega t)}## I worked with the equation of motion to get:
##-i\omega v_x = -\frac{e}{m}E_x - \omega_c v_y## and ##-i\omega v_y = -\frac{e}{m}E_y + \omega_c v_x##
Solving this system of equations, I end up with:
##v_x = \frac{-e}{m(\omega^2 - \omega_c^2)}(i\omega E_x +\omega_c E_y)## and ##v_x = \frac{-e}{m(\omega^2 - \omega_c^2)}(i\omega E_y -\omega_c E_x)##
Then I plug this into ##j = -nev## and get ##j = \frac{e^2(n_0 + \delta n(r, t))}{m(\omega^2 - \omega_c^2)}\begin{bmatrix}
i\omega E_x + \omega_c E_y\\
i\omega E_y - \omega_c E_x\\
\end{bmatrix}
And this is where I get stuck. I do not know how to deal with ##\delta n##, and I can't figure out how ##\epsilon_0## gets involved so that I can have ##\omega_p##. I also can't see how the time derivative will end up being just some constant times E, as ##\frac{\partial E_x}{\partial t} \alpha E_y## and ##\frac{\partial E_y}{\partial t} \alpha E_x## so it seems like $\alpha_{\pm}$ should be a tensor and not a constant.
Pushing forward with the time derivative despite this, I get:
##\frac{\partial j}{\partial t} =
\frac{e^2(\frac{\partial \delta n(r, t)}{\partial t}}{m(\omega^2 - \omega_c^2)}\begin{bmatrix}
\end{bmatrix} +
\pm i\omega^2 E_y \mp \omega_c \omega E_x\\
\mp i\omega^2 E_x \pm \omega_c \omega E_y\\
\end{bmatrix}
Which isn't proportional to E and has no ##\epsilon_0##
Multiply Lorentz's EOM BY -ne to get:
##mdj/dt=ne^2E+ej\times B_{ext}##.
Take: ##j=w e^{\alpha t}##
So you get the equation: ##m\alpha w=ne^2 E+ew\times B_{ext} ##.
Now, just match the coordinates of ##w=(w_1,w_2,w_3)## with with the rhs of the last above equation. don;t forget: ##B_{ext}=B\hat{z}##. where ##B## is a constant both in time and space.
You need to solve a Linear equations system
wait a minute in the last equation E should be multiplied by ##e^{\alpha t}##, in which case you should solve the equaiton whilst t=0.
I appreciate the reply, but I still have a few issues. ##\epsilon_0## is not involved, so I can't express my answer in terms of ##\omega_p##. Also, your solution would still result in ##\alpha_{\pm}## being tensors, while the problem requires them to be constants. Also, would your ##\alpha## be the same as the ##\omega## in the expression for ##\textbf{E}(\textbf{r}, t)## ? If not, then how would I derive ##\alpha##?
w is a vector alpha is a scalar, Obviously you need to use here vector analysis identities with the Dell operator; you should tinker with the identity. I would first take divergence on the equation and after that another equation with curl, and then equating the vector identities with their componenets while t=0.
Your Homework Statement looks like it relates to so-called "extraordinary" electromagnetic L,R waves in a plasma. I suggest you look at pp. 10-19 of these notes:
http://sun.stanford.edu/~sasha/PHYS312/2007/L11/phys312_2007_l11.pdf
for a discussion of these waves, which should help you solve your problem.
Thanks, It definitely is. I actually have already looked at those notes, although now that I'm looking at them again, I realized I was making some errors earlier, but even after correcting those and ignoring the ##\delta n## part of n, I still have a few problems.
Using the relations between ##E_x## and ##E_y## for R and L waves, I am able to get: ##\frac{dj}{dt} = \frac{\epsilon_0 \omega \omega_p^2}{1 \mp \frac{\omega_c}{\omega}}E##. My problem is that I have an extra factor of ##\epsilon_0## that I'm not supposed to have, as I'm required to express ##\alpha_{\pm}## solely in terms of ##\omega##, ##\omega_c##, and ##\omega_p##. With ##\omega_p = \frac{n_0^2e}{m\epsilon_0}##. I'm not sure how to resolve this. I also have a similar problem with k, where I'm stuck with an extra factor of 1/c.
You don't show your work so I have to ask if you're verifying your derivation against the reference (which uses gaussian units) that I cited in post #6?
The first equation there on top of pg. 12 is easily rewritten to read:$$\left(\frac{\omega^{2}}{c^{2}}-k^{2}\right)\vec{E}=\frac{4\pi}{c^{2}}\frac{d\vec{j}}{dt}\tag{1}$$whereas the two dispersion relations appearing on pg. 13 for L,R waves can be combined into the one relation:$$k^{2}c^{2}=\frac{\omega^{2}-\omega_{p}^{2}\pm\omega\omega_{c}}{1\pm\frac{\omega_{c}}{\omega}}\tag{2}$$Inserting (2) into (1) and solving for ##d\vec{j}/dt## gives:$$\frac{d\vec{j}}{dt}=\frac{1}{4\pi}\left(\frac{\omega_{p}^{2}}{1\pm\frac{\omega_{c}}{\omega}}\right)\vec{E}\tag{3}$$There's no evidence of anomalous factors of ##c^{-1}## in (2) or ##\epsilon_0\omega## in (3).
Note in my problem: ##\omega_p^2 = \frac{ne^2}{m\epsilon_0}##, unlike the lecture slides where ##\omega_p^2 = \frac{4\pi ne^2}{m}##.
Starting from my earlier solution for j:
##j = \frac{e^2n}{m(\omega^2 - \omega_c^2)}\begin{bmatrix}
\end{bmatrix}
##, and then using the relations for R waves that: ##E_x = -iE_y## and for L waves that: ##E_x = iE_y## and then combining these two as ##E_x = \mp iE_y##(The R wave corresponds to the + solution for the wave and the L wave corresponds to the - solution as defined in the beginning of the problem) I can rewrite this expression as:
i\omega E_x \pm i\omega_c E_x\\
i\omega E_y \pm i\omega_c E_y\\
\end{bmatrix}
which can be rewritten as:
##j = \frac{ie^2n}{m(\omega \mp \omega_c)}\textbf{E}
Which after taking a time derivative, and using ##E \propto e^{-i\omega t}## becomes:
##\frac{dj}{dt} = \frac{\omega e^2n}{m(\omega \mp \omega_c)}\textbf{E} = \frac{\epsilon_0 \omega \omega_p^2}{(\omega \mp \omega_c)}\textbf{E}
## a solution which has an extra ##\epsilon_0## I am not allowed to have.
To solve for ##k_{\pm}## I start with ##\nabla \times B = \mu_0 j + \mu_0\epsilon_0 \frac{\partial E}{\partial t}## and use ##\nabla \times B = ik\times B## with ##B = \frac{k}{\omega} \times E## from ##\nabla \times E = -\frac{\partial B}{\partial t}## to get ##\frac{i}{\omega}k \times k \times E = \mu_0 j + \mu_0\epsilon_0 \frac{\partial E}{\partial t}## then using the triple vector product identity along with ##E \propto e^{-i\omega t}## and ##k \dot E = 0## I get: ##-\frac{i}{\omega}k^2 E = \mu_0 j - i\omega\mu_0\epsilon_0 E##. Then, after some manipulation, I can get: ##c^2k^2E = \frac{i\omega j}{\epsilon_0)} + \omega^2 E## which can be rewritten as ##\frac{i \epsilon_0}{\omega}(\omega^2 - c^2k^2)E = j##, which using my previously found expression for j can be written as: ##i(\omega - \frac{c^2k^2}{\omega})E = \frac{\omega_p^2}{\omega^2 - \omega_c^2}\begin{bmatrix}
\end{bmatrix}
##, which, defining ##d = \frac{\omega_p^2}{\omega^2 -\omega_c^2}##, gives the system of equations:
##(\omega - \frac{c^2k^2}{\omega})E_x = d(\omega E_x - i\omega_c E_y)## and ##(\omega - \frac{c^2k^2}{\omega})E_y = d(\omega E_y + i\omega_c E_x)##, which can be manipulated to give: ##(1 - \frac{c^2k^2}{\omega^2} - d)E_x = -d i\frac{\omega_c}{\omega} E_y)## and ##(1 - \frac{c^2k^2}{\omega^2} - d)Ey = d i\frac{\omega_c}{\omega} E_x)##, which can be multiplied together to give:
##(1 - \frac{c^2k^2}{\omega^2} - d)^2 = \frac{\omega_c^2}{\omega^2}d##, which gives ##1 - \frac{c^2k^2}{\omega^2} - d = \pm\frac{\omega_c}{\omega}d##, which gives ##k^2 = \frac{\omega^2}{c^2}(1 - d(1 \pm \frac{\omega_c}{\omega}))## which is ##k^2 = \frac{\omega^2}{c^2}(1 - \frac{omega_p^2}{\omega^2 - \omega_c^2}(\frac{\omega \pm \omega_c}{\omega}))## which leads to ##k_{\pm} = \frac{\omega}{c}\sqrt{1 - \frac{\omega_p^2}{\omega^2 \mp \omega\omega_c}}##(choosing the positive solution as ##k > 0## since ##k \propto \frac{1}{\lambda}## and ##\lambda > 0##) and this solution is clearly proportional to ##\frac{1}{c}##. Then, just as confirmation, I can plug this value for k back into my earlier expression: ##\frac{i \epsilon_0}{\omega}(\omega^2 - c^2k^2)E = j## to get ##\frac{i \epsilon_0}{\omega}(\omega^2 - \omega^2( 1 - \frac{\omega_p^2}{\omega^2 \mp \omega\omega_c})) = j##, which gives: ##i\epsilon_0 \frac{\omega_p^2}{\omega \mp \omega_c} = j##, which using ##E \propto -e^{-i\omega t}##, gives ##\epsilon_0\omega\frac{\omega_p^2}{\omega \mp \omega_c} = \frac{dj}{dt}##, the same as I got earlier.
fizicksiscool said:
...a solution which has an extra ##\epsilon_0## I am not allowed to have.
Mea culpa! And my apologies for leading you astray by trying to compare your SI results directly to those in the gaussian class notes I referenced. I have independently verified your derivation and agree that the proper solution in SI units is ##\frac{d\vec{j}}{dt}=\left(\frac{\epsilon_{0}\omega_{p}^{2}}{1\mp\frac{\omega_{c}}{\omega}}\right)\vec{E}##. Note that the SI units on the left side of that equation are ##\frac{C}{m^{2}s^{2}}## and to get those same units on the right side, the permittivity ##\epsilon_{0}## must appear on the right. How certain are you that the requested solution to the problem cannot involve dimensional constants like ##\epsilon_0,\mu_0,\text{or }c ## in addition to ##\omega,\omega_p,\omega_c##?
