Carl140
- 49
When one calculates electric potentials, it involves integrating over the charge distribution, and for a surface with a uniform charge distribution, you encounter an integral of the form:
[tex]\int_{\mathcal{S}} \frac{d^2x'}{|\vec{x}-\vec{x'}|}[/tex]
Where [itex]\vec{x}[/itex] is the vector from the origin (in whatever coordinate system you choose) to the field point (the point at which you want to determine the potential), [itex]\vec{x'}[/itex] is the vector from the origin to a point on the surface containing the charge distribution, and the integration is over the source points.
Now I want to calculate this integral but in the following situation:
Here S is a surface which is bounded by two planes.
Here's a picture which illustrates the situation:
http://www.ccbm.jhu.edu/doc/presenta...sisDefense.pdf
Page 41, picture D. You can see the two planes I was referring two. Here "S" is the surface which is exactly in the middle. Now x is a point OUTSIDE of S and x' is a point in S (of course at least one of them must be outside S otherwise the denominator is not defined).
How can you approach this calculation?
