DAP1MP13
- 8
Stuck on two electric field questions...
Hi guys,
I have these two questions which I am unable to answer.
This is the first one:
Calculate the magnitude of the electric field at one corner of a square 1.26 m on a side if the other three corners are occupied by 2.80×10-6 C charges .
Hint: Draw the diagonal through the square from the lower left with one of the 3 charges to the upper right with the point where the electric field is wanted; the resulting field due to the 2 other source charges on either side of the diagonal points along the diagonal (why ?); calculate the magnitude for the vector sum; add this value to the field due to the charge on the lower left which also points along the diagonal (simply add the numbers).
I don't really even know how to start...(there is an example like this in my textbook 'physics'by Giancoli, but it is quite different from this question)
the second one:
A positive point charge Q1 = 3.43×10-5 C is fixed at the origin of coordinates, and a negative charge Q2 = -7.27×10-6 C is fixed to the x-axis at x = +1.97 m. Find the location of the place along the x-axis where the electric field due to these two charges is zero.
E = kQ/r^2
I set up E = 0 = 308700/1.97^2 - 65430/1.97^2
I set it to equal zero, but obviously that is incorrect.
I think I'm getting confused because one of the charges is set at the origin, it threw me off a little bit. So I know that for the first part the "r" should not be 1.97...
Any help is appreciated... thanks...
Hi guys,
the second one:
E = kQ/r^2
