Stuck on U-Substitution: Find Answer
  • MHB
  • Thread starter find_the_fun
  • Tags
    Stuck
In summary, the conversation is about integrating the expression \int \frac{cos(5x)}{e^{sin(5x)}} dx using the substitution u = sin(5x). After making the substitution, the integral becomes \frac{1}{5} \int \frac{1}{e^u} du. The conversation then discusses different ways to solve this integral, including rewriting \frac{1}{e^u} as e^{-u} and using the formula \int ax dx = ax/ln(a) + C. It is then suggested to use another substitution v = -u to simplify the integral further. Ultimately, the solution is given as \frac{-e^{-sin(5x)}}{5}
find_the_fun
148
I was practicing this question which is
\(\displaystyle \int \frac{cos(5x)}{e^{sin(5x)}} dx\)
let u=sin(5x) then \(\displaystyle \frac{du}{dx}=5cos(5x)\) which can be rewritten as \(\displaystyle \frac{1}{5}du = cos(5x) dx\)
Substituting u in gives \(\displaystyle \frac{1}{5} \int \frac{1}{e^u} du\)
This is where I get messed up. Can't you rewrite \(\displaystyle \frac{1}{e^u}\) as \(\displaystyle e^{-u}\)? and then use ∫ax dx = ax/ln(a) + C to get an answer? Is there really no elementary way to integrate \(\displaystyle e^{-u}\)?
Re: stuck on u substituion
You're on the right track there, since, by definition
\(\displaystyle \frac{1}{z^a}=z^{-a}\)Bearing that in mind, how does your solution pan out...?
All the best!
Gethin
Yes, you are correct when you state that the given substitution tranforms the indefinite integral into:
\(\displaystyle \frac{1}{5}\int e^{-u}\,du\)
Given that:
\(\displaystyle \frac{d}{du}\left(-e^{-u} \right)=e^{-u}\)
we may then write the integral as:
\(\displaystyle \frac{1}{5}\int\,d\left(-e^{-u} \right)\)
Can you proceed?
So I need to do u substitution again and use another variable?
Let \(\displaystyle v=-u\) then \(\displaystyle \frac{dv}{du}=-1\) rewriting gives \(\displaystyle -dv=du\)
So \(\displaystyle (-1)\frac{1}{5} \int e^v dv= \frac{-e^v}{5}+C=\frac{-e^{-u}}{5}+C=\frac{-e^{-sin(5x)}}{5}+C\)
Using the form I wrote, no further substitution is needed to integrate, since:
\(\displaystyle \int\,du=u+C\)
Once you apply this, then back-substitute for $u$.
FAQ: Stuck on U-Substitution: Find Answer
What is u-substitution?
U-substitution is a method used in calculus to simplify integrals that involve a function within a function. It involves substituting a new variable, u, for the inner function in order to make the integral easier to solve.
How do I know when to use u-substitution?
U-substitution is typically used when integrating a function that involves a composite function, or when the integrand involves a product or chain rule. Look for patterns such as the chain rule or a function within a function to determine when u-substitution may be applicable.
What is the process for using u-substitution?
The process for using u-substitution involves the following steps:
  • Identify the inner function and let u be equal to it
  • Find the derivative of u and substitute it into the integral
  • Solve for u and substitute back into the original integral
  • Simplify and solve the integral using basic integration techniques
Are there any common mistakes to avoid when using u-substitution?
One common mistake when using u-substitution is forgetting to substitute back in the original variable after solving for u. It is also important to correctly identify the inner function and choose a suitable u to substitute.
Can u-substitution be used for definite integrals?
Yes, u-substitution can be used for definite integrals. After solving for u and substituting back into the original integral, the limits of integration must also be adjusted to match the new variable.
