Studying Thin-Films: Do I Need Material Science Background?
A solid background in material science, physics, chemistry, and mathematics is essential for studying thin films. Understanding the fundamental properties and applications of thin films is crucial, as they are integral to various technologies, including electronics, optical coatings, and energy solutions like solar cells. Thin films, which range from nanometers to micrometers in thickness, require careful consideration of their compatibility with substrates and environmental conditions to ensure performance and durability. The field encompasses diverse applications, necessitating a broad scientific knowledge base to navigate the specific requirements of different thin film technologies. Engaging with various areas of material science before specializing in thin films is recommended to avoid limiting career opportunities and to appreciate the breadth of the field.
ahmedizeldin1981
Do I need to have a solid background in Material Science if I would like to study thin-films?
Hello @ahmedizeldin1981 ,
:welcome: ##\qquad## !​
Depends on the kind of thin film you are thinking of, and we have to guess at, apparently ...
Nice exercise in telepathy, but I failed :frown:
Likes sophiecentaur
You would need a pretty solid background in Science before you could be really sure you want to spend your life with Thin Films. Without a fair bit of knowledge of things in general, you could never be able to appreciate what that field would actually involve.
If you have been inside a Thin Films Lab and seen some interesting work going on then I can appreciate it would be an attractive idea. But there are thousands of labs all over the world doing stuff that's just as interesting - once you get down to it. So I think you should avoid getting too set on one direction of study until you have studied the whole field. That would avoid both possible disappointment and missing out on fascinating alternatives.
Probably, yes, to some extent. One probably needs a good background in physics and chemistry (and math, of course). As sophiecentaur implied, one should have a diversified scientific (materials) background in order to ensure a continuing career (onging employment) in broader or related fields.
Consider what a thin film is and does.
https://en.wikipedia.org/wiki/Thin_film
A thin film is a layer of material ranging from fractions of a nanometer (monolayer) to several micrometers in thickness. The controlled synthesis of materials as thin films (a process referred to as deposition) is a fundamental step in many applications. A familiar example is the household mirror, which typically has a thin metal coating on the back of a sheet of glass to form a reflective interface. The process of silvering was once commonly used to produce mirrors, while more recently the metal layer is deposited using techniques such as sputtering. Advances in thin film deposition techniques during the 20th century have enabled a wide range of technological breakthroughs in areas such as magnetic recording media, electronic semiconductor devices, Integrated passive devices, LEDs, optical coatings (such as antireflective coatings), hard coatings on cutting tools, and for both energy generation (e.g. thin-film solar cells) and storage (thin-film batteries). It is also being applied to pharmaceuticals, via thin-film drug delivery. A stack of thin films is called a multilayer.
Optical or magnetic surfaces are one area of application. Wear/galling resistance is yet another area, and corrosion/chemical resistance, chemical reactivity (catalysis), heat transfer or heat resistance (insulation), and electrical conduction or resistance (electrical insulation) are still other areas of interest.
A thin film will have specific properties for specific uses, and one then applies a film to a substrate, which has its special properties and purpose. One has to tailor the thin film to an environment, so there must be resistance to film degradation. The thin film must be compatible with the underlying substrate.
In one example, an thin film may provide protection to the underlying substrate, and so the film and substrate must be chemically compatible over the range of operating/environmental conditions. One should try to match thermal expansion and mechanical strain capabilities over the range of operating temperatures. The protective film cannot crack, or if it does, it should be self-healing.
In developing a thin-film/substrate system, there are numerous bits of physics one must understand, or one must know someone(s) who understand certain bits of physics and how they are inter-related.
Likes dlgoff and sophiecentaur
"Thin films" is not really an area as such. There are undergraduate courses that might e.g. deal with how thin films grow when deposited using different methods and also some of the underlying thermodynamics and surface physics. However, once you start looking into the specifics of how they are used for different applications the areas quickly diverge.
Pretty much all modern electronics uses thin films meaning it is a huge area and the specifics are therefore usually "covered" by that specific field. Someone working on depositing anti-reflection coatings for photonics using CVD won';t necessarily have much in common with someone working with high-Tc superconducting devices; they would both the using a clean room and some of the same tools but that is about it.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
