Sturm-Liouiville: Why Does Integral Equal 0 or m=n?
  • MHB
  • Thread starter Dustinsfl
In summary, the given conversation discusses the equality of two integrals and its implications. It is shown that the equality of the integrals does not imply anything and the question may have been referring to a different equation. The conversation then moves on to discussing the Legendre polynomials and their properties. It is shown that the eigenfunctions corresponding to different eigenvalues of the Sturm-Liouville DE are orthogonal.
Dustinsfl
2,281
Given
\lambda^2\int_{-1}^1y_ny_mdx = \lambda^2\int_{-1}^1y_my_ndx
Why does this imply that either $m = n$ or the integral is 0?
You've marked this thread as solved. I'm a bit puzzled by the question myself, though. The two integrals are equal, period, because multiplication is commutative. The equality of those two integrals implies nothing whatsoever. Did you mean, instead, that
$$\lambda^{2}\int_{-1}^{1}y_{n}y_{n}\,dx=\lambda^{2}\int_{-1}^{1}y_{m}y_{m}\,dx?$$
I was looking at a paper about the Legendre polynomials, and I didn't understand what they were doing. I then realized they should have indexed there lambdas.We can rewrite $(1 - x^2)y_{\ell}'' - 2xy_{\ell}' + \left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}$ as
\begin{alignat}{3}
\frac{d}{dx}\left[(1 - x^2)y_{\ell}'\right] + \left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell} & = & 0\notag\\
\frac{d}{dx}\left[(1 - x^2)y_{\ell}'\right] & = & - \left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}\notag\\
y_n\frac{d}{dx}\left[(1 - x^2)y_{\ell}'\right] & = & - \left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_n\notag\\
\int_{-1}^1y_n\left[(1 - x^2)y_{\ell}'\right]'dx & = & - \int_{-1}^1\left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_ndx
\end{alignat}
Integrating (2) by parts where $u = y_n$ and $dv = [(1 - x^2)y_{\ell}']'$, we have
\begin{alignat*}{3}
\underbrace{\left.(1 - x^2)y_n'y_{\ell}\right|_{-1}^1}_{ = 0} - \int_{-1}^1(1 - x^2)y_n'y_{\ell}'dx & = & - \int_{-1}^1\left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_ndx\\
\int_{-1}^1(1 - x^2)y_n'y_{\ell}'dx & = & \int_{-1}^1\left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_ndx
\end{alignat*}
Since we could have started with $y_n$ and the choice of $y_{\ell}$ was arbitrary, we would also have
\int_{-1}^1(1 - x^2)y_n'y_{\ell}'dx = \int_{-1}^1\left(\lambda_{n}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_ndx.
Therefore, we have that
\begin{alignat*}{3}
\int_{-1}^1\left(\lambda_{n}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_ndx & = & \int_{-1}^1\left(\lambda_{\ell}^2 - \frac{m^2}{1 - x^2}\right)y_{\ell}y_ndx\\
\int_{-1}^1\left(\lambda_{n}^2y_{\ell}y_n - \frac{m^2}{1 - x^2}y_{\ell}y_n - \lambda_{\ell}^2y_{\ell}y_n + \frac{m^2}{1 - x^2}y_{\ell}y_n\right)dx & = & 0\\
(\lambda_n^2 - \lambda_{\ell}^2)\int_{-1}^1y_{\ell}yndx & = & 0
\end{alignat*}
When $n\neq\ell$, $\lambda_n^2 - \lambda_{\ell}^2$ is non-zero; therefore, $\int_{-1}^1y_{\ell}yndx = 0$.
Ah, yes; the standard argument that for an Hermitian operator (corresponding to the Sturm-Liouville DE), eigenfunctions corresponding to different eigenvalues are orthogonal.
The Sturm-Liouville equation is a fundamental concept in mathematics and physics, and it is used to solve various differential equations. In this context, the given equation represents an eigenvalue problem, where $\lambda$ is the eigenvalue and $y_n$ and $y_m$ are the eigenfunctions corresponding to the eigenvalues $n$ and $m$, respectively.
The fact that the integral on the left-hand side of the equation is equal to the integral on the right-hand side implies that the eigenfunctions $y_n$ and $y_m$ are orthogonal over the interval $[-1, 1]$. This means that the integral of the product of $y_n$ and $y_m$ over the interval is equal to 0, unless $n = m$.
This is a result of the orthogonality property of eigenfunctions, which states that the inner product of two distinct eigenfunctions is equal to 0. Therefore, the given equation implies that either $m = n$, in which case the integral is non-zero, or $m \neq n$, in which case the integral is equal to 0.
In conclusion, the given equation is a manifestation of the fundamental orthogonality property of eigenfunctions, which explains why the integral is either 0 or equal to the eigenvalue squared. This result is crucial in solving differential equations and has many important applications in various fields of science and engineering.
FAQ: Sturm-Liouiville: Why Does Integral Equal 0 or m=n?
Why do we use Sturm-Liouville equations?
The Sturm-Liouville equation is a powerful tool in solving differential equations in various fields such as physics, engineering, and mathematics. It allows us to express a wide range of problems in a standard form, making it easier to find analytical solutions.
What is the significance of the integral in the Sturm-Liouville equation?
The integral in the Sturm-Liouville equation represents the orthogonality of the eigenfunctions. This means that the eigenfunctions are perpendicular to each other, making them useful in solving boundary value problems where we need to find a unique solution.
Why does the integral equal 0 or m=n in Sturm-Liouville equations?
This is due to the orthogonality of the eigenfunctions. If m does not equal n, then the integral of the product of the eigenfunctions will be equal to 0. If m equals n, then the integral will equal the eigenvalue, which can be any nonzero value. This property is crucial in determining the eigenvalues and eigenfunctions in Sturm-Liouville problems.
How do we determine the eigenvalues and eigenfunctions in Sturm-Liouville problems?
The eigenvalues and eigenfunctions can be found by solving the Sturm-Liouville equation and using boundary conditions to determine the constants in the solutions. The orthogonality property can also be used to find the eigenvalues by setting the integral to 0 or m=n and solving for the eigenvalues.
Can Sturm-Liouville equations be applied to real-world problems?
Yes, Sturm-Liouville equations are widely used in various fields to model physical phenomena. They have been applied in areas such as heat transfer, fluid mechanics, quantum mechanics, and many more. By using Sturm-Liouville equations, we can find analytical solutions that accurately describe the behavior of these systems.
