ChrisJ
- 70
- 3
Using Sturm-Liouville theory, estimate the lowest eigenvalue ##\lambda_0## of...
[tex]
\frac{d^2y}{dx^2}+\lambda xy = 0
[/tex]
With the boundary conditions, ##y(0)=y(\pi)=0##
And explain why your estimate but be strictly greater than ##\lambda_0##
##\frac{d}{dx} \left (p \frac{dy}{dx} \right) + qy + \lambda \rho y = 0 ##
##\frac{I}{J}=\frac{\int (p (y')^2 - qy^2) dx}{\int \rho y^2 dx} ##
I am rather stuck here I think, I am so confused, I am pretty sure our lecturer said we had to use the variatonal method but I cannot see how to do that here.
But somewhere in my notes it says that the eigenvalues of a SL equation are given by I/J (second equation in the relevant equations section).
So to make a start that is what I did. Comparing the Sl equation with the equation given to solve, I can see that ##p=1##, ##q=0##, and ##\rho(x) = x## where ##\rho## is the weight function. And I used the trial function that ##y(x)=\sin(x)##
So I calcuated I/J (lower limit 0, upper limit ##\pi## for the integrals), using integration by parts and trig identities for J and simple trig identities and u-sub for I.
I found ##I=\pi/2## and ##J=\pi^2/4## so therefore ##I/J=2/\pi## I didnt post all my working because I doubled checked it in an integral calculator. But now I am lost. That cannot just be it.
I don't understand how to use the variational method here, all examples I have seen using the SL variational method online were to solve problem where a trial function of ##e^{-\alpha x^2} ## satisfied the BC's and the problems required integrating I/J from -'ve to +'ve infinity, and then setting it to zero and solving for ##\alpha## I can't see how I can use that method in this problem.
Or if that even is what is required. Any help is greatly appreciated, really lost here.
