SU(3) Cartan Generators in Adjoint Representation
In summary: B%7B0,-i,√3/2,√3/2,1,0,0,1/2,1/2,1%7D,+%7Bi,√3/2,√3/2,0,0,0,0,0,0%7D,+%7B0,√3/2,√3/2,1,0,0,0,0,0%7D,+++%7B0,√3/2,√3/2,-i%2F2,0
nigelscott
135
I am trying to work out the weights of the adjoint representation of SU(3) by calculating the 2 Cartan
generators as follows:
I obtain the structure constants from λa and λ8 using:
ab] = ifabcλc
I get:
f312 = 1
f321 = -1
f345 = 1/2
f354 = -1/2
f367 = -1/2
f376 = 1/2
f845 = √3/2
f854 = -√3/2
f876 = -√3/2
f867 = √3/2
I construct the matrices from:
(T1)ab = -if3ab and (T2)ab = -if8ab
I then diagonalize the resulting matrices and get the eigenvalues::
T1 = diag(-1/2,-1/2,1,0,0,-1,1/2,1/2)
T2 = diag(-√3/2,-√3/2,0,0,0,0,√3/2,√3/2)
Which is close but not correct. I think the problem may be with diagonalizing the matrices individually
rather than simultaneously as the eigenvectors don't match. Before, I begin that journey, however, I wanted
to samity check what I am doing. I am following Zee's lecture which can be found at:
https://www.youtube.com/watch?v=u-g9hzDByJ8 minute ~ 5
Any help would be appreciated.
May I ask you why you want to do this? There's a reason why textbooks use ##\mathfrak{sl}(2)##, resp. ##\mathfrak{su}(2)##, as example. ##\mathfrak{su}(3)## is a case where it really has to be considered to write a computer program instead. I assume the CSA is spanned by the diagonal matrices ##i \lambda_3, i\lambda_8## and would as a first step try to find a basis for the Borel subalgebra (maximal solvable subalgebra). Then you know at least the ascending and descending elements. You can find an educated guess here. To work out the entire example with structure constants is quite troublesome, so I would remain as general as long as possible, i.e. write down the equations by using basis vectors, rather than structure constants. Besides all this, I guess the representations could be found on the internet.
Yes, your point is well taken. I realize that this is a tedious approach and the eigenvalues can be found more easily using [Hi,Eα] = αiEα where Eα are the I, U and V spin operators. However, my approach should work correct? In the defining rep the 3 x 3 Cartan generators share the same eigenbasis and so I would expect that the 8 x 8's would too. However, I am not seeing that. Either my structure constants are wrong or my approach is not valid. I used λ not iλ in my calculations. Could that be a problem?
It shouldn't be a problem. I just find it confusing to work with Lie algebras and their representations and the theorems available, but without having one. The Gell-Mann matrices are simply not skew Hermitian, which should affect the eigenvalues, so caution is required.
Wikipedia has the structure constants, so you can check them. I probably would just calculate the ##[\lambda_\alpha,\lambda_\beta]##. Should be easy and the imaginary factor can be easily applied as well, so you can have both in parallel, or look them up.
I still find it more convenient to work with ##[H^i,E_\alpha].v = E_\alpha.v## to get to ##H^i(E_\alpha.v)=(\alpha^i+\mu_i)E_\alpha.v## rather than the whole thing in coordinates. I only renamed the eigenvalues ##\mu_i## to avoid confusion with the Gell-Mann matrices. And if the representation isn't the natural one, you'll need this more general approach anyway. However, you said to use only the adjoint representation. In this case: why don't you just do matrix multiplications? ##\operatorname{ad} i\lambda_\alpha . i\lambda_\beta = - [ \lambda_\alpha , \lambda_\beta ] = \sum f_{\alpha \beta}^k (i\lambda_k)## gives you eight nice ##8 \times 8## matrices. I only would avoid to calculate ##\operatorname{Ad}## by exponentiation.
##\operatorname{ad}i \lambda_3## and ##\operatorname{ad} i \lambda_8## two are commuting semisimple linear transformations, so it should be no problem to verify the basis vectors of the eigenspaces.
I am still struggling with interpreting the results I get. For ad( H1) and ad( H2) I get:
Diagonalization using WolframAlpha gives:
ad(H1): diag(-1,-1/2,-1/2,,0,0,1/2,1/2,1)
ad(H2): diag(0,0,0,0,-√3/2,-√;-3/2,√;3/2,√;3/2)
1. All the weights are there but not in the correct order.
2. 6/8 eigenstates of ad(H1) and ad(H2) match. 2 are different.
I still can't figure out what is going on.
WolframAlpha diagonalization links:
ad(H1): http://www.wolframalpha.com/input/?...,0},+{0,0,0,0,0,-i/2,0,0},+{0,0,0,0,0,0,0,0}}
ad(H2): http://www.wolframalpha.com/input/?...0,0,0,0,0,i√3/2,0,0},{0,0,0,0,0,0,0,0}}
Here is what I have.
I used the basis conventions at the end of https://www.physicsforums.com/insights/representations-precision-important/ , i.e. the numeration of the ##\lambda -##matrices, as well as
$$\left\{ \,H_1:=T_3=\frac{1}{2}\lambda_3\; , \;H_2:=Y\; , E_{\pm\alpha} :=iT_{\pm}\; , \;E_{\pm\beta} :=iU_{\pm}\; , \; E_{\pm(\alpha +\beta)}:=iV_{\pm}\;\,\right\}$$
Because it's far easier to calculate commutators, I set ##e_{ij}## to be the matrix with a single ##1## at position ##(i,j)## and ##0## elsewhere. This gave me
$$H_1=\frac{1}{2}e_{11}-\frac{1}{2}e_{22}\; , \;H_2=\frac{1}{3}e_{11}+\frac{1}{3}e_{22}-\frac{2}{3}e_{33} $$
E_\alpha =ie_{12}\; , \;E_{-\alpha}=ie_{21}\; , \;E_{\beta}=ie_{23}\; , \;E_{-\beta}=ie_{32}\; , \;E_{\alpha + \beta}=ie_{13}\; , \;E_{-\alpha - \beta}=ie_{31}
in the usual notation of the Cartan subalgebra and the corresponding root vectors.
If I made no sign errors and no typos, I had the following multiplications:
##\operatorname{ad}H_1.(E_{\alpha},E_{-\alpha},E_{\beta},E_{-\beta},E_{\alpha + \beta},E_{-\alpha - \beta}) = (E_{\alpha},-E_{-\alpha},-\frac{1}{2}E_{\beta},\frac{1}{2}E_{-\beta},\frac{1}{2}E_{\alpha + \beta},-\frac{1}{2}E_{-\alpha - \beta})##
##\operatorname{ad}H_2.(E_{\alpha},E_{-\alpha},E_{\beta},E_{-\beta},E_{\alpha + \beta},E_{-\alpha - \beta}) = (0,0,E_{\beta},-E_{-\beta},\sqrt{3}E_{\alpha + \beta},-\sqrt{3}E_{-\alpha - \beta})##
which looks good so far. I also have ##[E_{\pm \alpha\, , \,E_{\pm \beta}}] = \pm i \cdot E_{\pm (\alpha + \beta)}## as a kind of parity check, and I didn't calculate the rest.
If the ##E_\alpha## should be made into ##SU(3)## elements, so probably ##E_\alpha \longrightarrow i \cdot \lambda = E_\alpha + E_{-\alpha}\; , \; E_{-\alpha} \longrightarrow E_\alpha - E_{-\alpha}## etc. should be the right choices. Otherwise with the choices I've made, we only get an isomorphic version of it, i.e. still the same Lie algebra, but not skew-Hermitian anymore. But as a Lie algebra, my non-Hermitian basis is eventually easier to handle.
Related to SU(3) Cartan Generators in Adjoint Representation
1. What is the SU(3) Cartan subalgebra?
The SU(3) Cartan subalgebra is a subset of the SU(3) Lie algebra that consists of diagonal matrices with trace equal to zero. These matrices are called Cartan generators and they play a crucial role in the theory of SU(3) representations.
2. What is the Adjoint representation in SU(3)?
The Adjoint representation in SU(3) is a way of representing the Lie algebra elements as matrices acting on a vector space. In this representation, the Cartan generators of SU(3) are represented by traceless Hermitian matrices with specific properties.
3. How are the Cartan generators related to the root system of SU(3)?
The Cartan generators of SU(3) are intimately related to the root system of the Lie algebra. They correspond to the simple roots of SU(3) and are used to construct all other roots and weights of the algebra. In fact, the Cartan generators are the basis for the weight space of SU(3).
4. What are the properties of the Cartan generators in the Adjoint representation?
The Cartan generators in the Adjoint representation of SU(3) have several important properties. They are traceless, Hermitian matrices, and they commute with each other. They also form a basis for the Lie algebra and are used to label the irreducible representations of SU(3).
5. How do the Cartan generators act on the fundamental representation of SU(3)?
The Cartan generators act on the fundamental representation of SU(3) by generating rotations and transformations within the representation. These rotations and transformations correspond to the symmetries of the fundamental representation and are crucial in understanding the behavior of particles in SU(3) gauge theories.
  • Differential Geometry
