Subcritical Pitchfork Bifurcation
  • Thread starter glebovg
  • Tags
    Bifurcation
In summary: It's probably because I'm not familiar enough with the software to make it look nice.In summary, the homework statement is to find algebraic expressions for all the fixed points in a subcritical pitchfork bifurcation, and to calculate the parameter value at which the nonzero fixed points are born.
glebovg
164
Consider the system dx/dt = rx + x^3 - x^5, which exhibits a subcritical pitchfork bifurcation.
a) Find algebraic expressions for all the fixed points.
b) Calculate r_s, the parameter value at which the nonzero fixed points are born in a saddle-node bifurcation.
The attempt at a solution
x* = 0 and x* = ±√½±½√4r+1.
For (b), why not check out the Wikipedia reference on pitchfork bifurcation, check all those derivatives and determine which value of r satisfies them. That's not too hard right? Then if you want to and you're into Mathematica, check out this code which draws the slope field and bifurcation diagram. Experiment with it to see how the fixed points are created and destroyed at the bifurcation point:
Code:
myStableVals = {};
myUnstableVals = {};
For[r2 = -1, r2 <= 1, r2 += 0.01, {thereals = Select[x /. Solve[r2*x + x^3 - x^5 == 0, x], Element[#1, Reals] & ]; rlen = Length[thereals];
     For[i = 1, i <= rlen, i++, {If[(r2 + 3*x^2 - 5*x^4 /. x -> thereals[[i]]) <= 0, myStableVals = Append[myStableVals, {r2, thereals[[i]]}],
         myUnstableVals = Append[myUnstableVals, {r2, thereals[[i]]}]]; }]; }];
lp1 = ListPlot[myStableVals, PlotRange -> {{-1, 1}, {-3, 3}}, PlotStyle -> Blue];
lp2 = ListPlot[myUnstableVals, PlotRange -> {{-1, 1}, {-3, 3}}, PlotStyle -> Red];
Show[{lp1, lp2}]
Manipulate[thereals = Select[x /. Solve[r2*x + x^3 - x^5 == 0, x], Element[#1, Reals] & ];
   theeqpoints = Graphics[{Red, Thickness[0.01], (Line[{{-5, #1}, {5, #1}}] & ) /@ thereals}];
   Show[{StreamPlot[{1, r2*x + x^3 - x^5}, {t, -5, 5}, {x, -2, 2}, StreamPoints -> 45], theeqpoints}], {r2, -1, 1}]
Thank you.
It can be instructive to simply plot [itex]rx + x^{3} - x^{5} = x ( r + x^{2} - x^{4} ) [/itex] for various values of r , knowing that the y-axis represents dx/dt . Zeroes of the polynomial for which the slope is positive represent unstable equilibria, while those with negative slope represent stable equilibria. The equilibrium point at x* = 0 is always there for any choice of r . If you check your solution for the zeroes of [itex] r + x^{2} - x^{4} [/itex], by the way, I think you'll find that your expression for the other equilibria should be
[tex] x* = \pm[ {\frac{1}{2}} \pm \frac{1}{2} \cdot \sqrt{1 + 4r} ]^{1/2} .[/tex]
[EDIT: as I re-read this, I guess that is what you intend, but your expression would benefit from the insertion of some parentheses.]
There are actually three cases to consider:
(1) for large positive r , the "minus" within the square bracket is inapplicable because it makes the term under the "main square root" negative; in this case there are only two zeroes for dx/dt besides x* = 0 ;
there is a critical value of r (what is it?) where the situation changes and we have
(2) the "minus" become admissible, so there are now four zeroes for dx/dt , in addition to the one at x* = 0 ; also, look at what happens to the nature of the equilibrium at x* = 0 ;
finally, there is another critical value of r (what is this?) where
(3) just at that value, the number of zeroes other than x* = 0 is three again, but beyond that value, the expression under the "inner square root" is negative, permitting no other zero besides x* = 0 .
The approach of plotting the direction field, which jackmell suggested, is certainly also useful and illustrative, but analysis of the function for dx/dt can pinpoint critical values of parameters (if the function isn't too "hairy"), and will also aid in interpreting what the direction field plots are showing us.
Ok, that's better. Thanks. Wish to point out that this equation is just a cross-section of a more general expression:
[tex]\frac{dx}{dt}=ax^5+bx^3+cx^2+dx+e[/tex]
which exhibits the butterfly catastrophe, one of the seven elementary catastrophies in Catastrophe Theory. I tried to plot the equilibrium surface for:
[tex]\frac{dx}{dt}=-x^5+x^3+cx^2+rx[/tex]
via the Mathematica code:
Code:
thesheet = x /. Solve[-x^5 + x^3 + 3*u*x^2 + r*x == 0, x];
Plot3D[Evaluate[thesheet], {u, -1, 1}, {r, -3, 3}, PlotPoints -> 75, BoxRatios -> {1, 1, 1}]
below but can't do a nice job. The bifurcation diagram I mentioned in my first post is just a cross-section of this plot.
Not trying to out-do Dynamic up there. Just pointing out to the young students in here that in my opinion, many of the puzzling phenomena in our world can be framed within the context of Catastrophe Theory and equations like this so you guys might want to consider studying them. That's one reason I do. :)
Thank you for this additional remark. There are many useful ways to visualize the behavior of dynamical systems, and I appreciate your providing the description via catastrophe theory. (CT is little emphasized in what I have been reading, so I found this alternative approach of interest.)
[Incidentally, in my post (#4), for case (3), that should read, "... other than x* = 0 is two again, ..." . I just missed the 700-minute deadline for fixing the error up there.]
Related to Subcritical Pitchfork Bifurcation
1. What is a subcritical pitchfork bifurcation?
A subcritical pitchfork bifurcation is a type of bifurcation, or branching of a system's behavior, that occurs when a system undergoes a change in a parameter and experiences a sudden change in its equilibrium state. It is called "subcritical" because the bifurcation occurs when the parameter is below a critical value.
2. How does a subcritical pitchfork bifurcation differ from a supercritical pitchfork bifurcation?
A subcritical pitchfork bifurcation differs from a supercritical pitchfork bifurcation in that it occurs when the parameter is below a critical value, whereas a supercritical pitchfork bifurcation occurs when the parameter is above a critical value. This results in different behaviors of the system, with a subcritical bifurcation causing a sudden change in the stability of the equilibrium state.
3. What are some real-life examples of subcritical pitchfork bifurcations?
Subcritical pitchfork bifurcations can be seen in a variety of systems, such as population dynamics, chemical reactions, and economic models. For example, in population dynamics, a subcritical pitchfork bifurcation can occur when a change in environmental conditions causes a sudden shift in the size or stability of a population.
4. How is a subcritical pitchfork bifurcation analyzed?
A subcritical pitchfork bifurcation can be analyzed using mathematical models and simulations. This involves studying the system's equations and identifying the critical parameter value that triggers the bifurcation. The stability and behavior of the equilibrium state can also be analyzed using bifurcation diagrams and phase portraits.
5. Can subcritical pitchfork bifurcations be controlled or avoided?
In some cases, it may be possible to control or avoid a subcritical pitchfork bifurcation by manipulating the system's parameters. This can be done by introducing external influences or by adjusting the system's internal dynamics. However, in complex systems, it may be difficult to predict and control bifurcations, making them an important area of study in science.
