ConfusedMonkey
- 42
- 15
Consider the map ##\phi: \mathbb{R}^4 \rightarrow \mathbb{R}^2## defined by ##\phi(x,y,s,t) = (x^2 + y, x^2 + y^2 + s^2 + t^2 + y)##.
Show that ##(0,1)## is a regular value of ##\phi##, and that the level set ##\phi^{-1}(0,1)## is diffeomorphic to ##\mathbb{S}^2##.
[/B]
I get two equations describing the level set:
(1) ##x^2 + y = 0 \implies y = -x^2##
(2) ##x^2 + y^2 + s^2 + t^2 + y = 1 \implies y^2 + s^2 + t^2 = 1##
So ##\phi^{-1}(0,1) = \{(x,y,s,t) \in \mathbb{R}^4: y = -x^2 \hspace{0.1cm} \mathrm{ and } \hspace{0.1cm} y^2 + s^2 + t^2 = 1\}##.
I need to show that ##d\phi(x,y,s,t)## is surjective for all ##(x,y,s,t) \in \phi^{-1}(0,1)##. I calculate:
##d\phi(x,y,s,t) = \begin{pmatrix} 2x & 1 & 0 & 0 \\ 2x & 2y + 1 & 2s & 2t \end{pmatrix}##
It is easy to show that this matrix has rank ##2## for all ##(x,y,s,t) \in \phi^{-1}(0,1)## and so ##\phi^{-1}(0,1)## is an embedded submanifold of ##\mathbb{R}^4##. Quick question: Did I calculate the differential properly?
Now, I need to show that this level set is diffeomorphic to the unit sphere. I can kind of see that it may be diffeomorphic to a spheroid, and I know I can show that the spheroid is diffeomorphic to the sphere. My only problem is coming up with this diffeomorphism from the level set onto the spheroid.
I imagine I can define a map ##\psi: \phi^{-1}(0,1) \rightarrow S## by ##\psi(x,y,s,t) = (x,s,t)##, where ##S = \psi(\phi^{-1}(0,1))##. It is easy to see that this map is invertible and its inverse is given by ##\psi^{-1}(x,s,t) = (x, -x^2, s, t)## since ##y = -x^2##. My only trouble is showing that these maps are both smooth. Both the domain and codomain are submanifolds of ##\mathbb{R}^4## and ##\mathbb{R}^3##, respectively, so I need to express ##\psi## in appropriate local coordinates before differentiating, but coming up with these local coordinates seems like I am making things overly complicated. What would you suggest I do?
