Substance is in equilibrium between its vapour and liquid
In summary, the rate of evaporation and condensation are equal in a substance that is in equilibrium between its vapour and liquid states, including any dissolved gas molecules. When a substance becomes aqueous, it is still considered a change of state, and if the solvent is the same substance, it is still accounted for in the equilibrium equation. Each substance in the solution has its own separate gas/liquid equilibrium.
MathewsMD
433
In Chemistry, if a substance is in equilibrium between its vapour and liquid, does it account for the dissolved gas molecules?
I have always heard that the rate of evaporate = rate of condensation in a case like this, but does the rate of evaporation include the dissolved gases escaping and other gas molecules dissolving? Since can this be technically considered a change of state since it is becoming aqueous (if water solvent) but what is it called if the solvent is the same substance? In either case, water or the same substance acting as the solvent, is this accounted for in the equilibrium equation or is this completely different?
Chemistry news on Phys.org
The short answer is that it's already accounted for. It is not possible to distinguish "dissolved" water molecules in the liquid from the rest of the molecules in the liquid. Once a water molecule enters the liquid, it is just the same as any other water molecule in the liquid (since it undergoes rapid collisions and exchanges energy rapidly).
Each substance present in the solution has its own separate gas/liquid equilibrium, so you can have solution that is in equilibrium in regard to one substance and not in equilibrium with regard to another. But it can also be in equilibrium in regard to all substances.
Related to Substance is in equilibrium between its vapour and liquid
1. What does it mean for a substance to be in equilibrium between its vapour and liquid states?
Equilibrium between a substance's vapour and liquid states means that the rate of evaporation of the liquid is equal to the rate of condensation of the vapour, resulting in no net change in the amount of the substance in either state.
2. How is equilibrium between vapour and liquid states achieved?
Equilibrium between vapour and liquid states is achieved when the substance reaches its boiling point, which is the temperature at which the vapour pressure of the liquid is equal to the atmospheric pressure.
3. Can equilibrium between vapour and liquid states be altered?
Yes, equilibrium between vapour and liquid states can be altered by changing the temperature or pressure of the system. For example, increasing the temperature will increase the vapour pressure, shifting the equilibrium towards the vapour state.
4. Why is it important to understand equilibrium between vapour and liquid states?
Understanding equilibrium between vapour and liquid states is important in many industrial processes, such as distillation, where the separation of different components relies on their different vapour pressures at a given temperature. It is also important in the study of phase transitions and thermodynamics.
5. How is equilibrium between vapour and liquid states affected by the properties of the substance?
The properties of the substance, such as its boiling point and vapour pressure, will determine the conditions under which equilibrium between vapour and liquid states can be achieved. For example, substances with higher vapour pressures will reach equilibrium at lower temperatures, and vice versa.
  • Chemistry
  • Mechanical Engineering
