Substance or chemical reaction, that is highest rate in changing mass
In summary, the conversation discusses the possibility of achieving a high rate of immediate mass change using only homemade DIY materials and equipment within the range of 1-250 grams. It is clarified that chemical reactions do not change mass, but some reactions can release gases or use atmospheric elements to bind to other materials. However, it is unlikely to achieve a significant mass change at a tactile level using these methods. Fuel cells are mentioned as a possible option, but they require significant energy and setup weight.
roineust
338
Hello!
What would be the substance, chemical reaction and technique, to have the highest rate of immediate mass change, back and forth, from low to high and back to low again, as many times as needed - using only homemade DIY, non dangerous materials and equipment?
My intentions are to deal in the range of 1-250 grams.
What would be the change under these DIY home limitations?
Would it be a change of between, say, 10 grams and 10.2 grams or is there some marvelous material mass transforming 'magic', that can make 10 grams become 100 grams, almost instantly and then again, almost instantly or when needed, back to 10 grams?
I understand that this questions might uncover some basic misunderstanding of some elementary modern physics principles (i hope not of classical physics as well...), but that's the situation here and we shall appreciate a detailed, as well as simple answer as possible!
Thanks!
Chemistry news on Phys.org
Chemical reactions never change the masses*. In some reactions, you can create gases that escape, or use parts of the atmosphere (like oxygen) to bind it to your other materials, but the total mass of the products is always the same as the total mass of the chemicals used for the reaction.
This is purely classical physics - after the reaction you have the same atoms as before, just in a different arrangement.
*apart from extremely tiny relativistic effects way too small to be relevant
Thanks,
But is there any technique, to bind oxygen from the air, to a certain substance, up to a needed level and then to release the same amount or oxygen or other non harmful gas and have these changes very fast and at such a mass change level, that can be felt at a tactile level? say, at least a difference of +- 5 grams? or am i still misunderstanding some basic physical/chemical principle?
I doubt that. Most reactions with oxygen (or nitrogen) release so much heat that they are hard to reverse - even if you are lucky and don't produce escaping water vapor or CO2 in the reaction. And even if you find such a reaction, you would have to heat the material in such a way that it does not react with oxygen again afterwards.
A 1-way reaction is easier. Just burn wood ;).
Fuel cells can reach +- 5 grams if you can store ~5 liters of hydrogen, but that is a very slow process and you need significant electric energy to reverse the reaction - and the setup will have a significant weight so you don't note a difference of 5 grams without a scale.
Gotcha!
Thanks!
FAQ: Substance or chemical reaction, that is highest rate in changing mass
1. What is meant by "highest rate in changing mass" in a substance or chemical reaction?
The highest rate in changing mass refers to the speed at which the mass of a substance or chemical reaction changes over time. This can be affected by factors such as temperature, pressure, and concentration.
2. How is the rate of change in mass determined in a substance or chemical reaction?
The rate of change in mass is determined by measuring the difference in mass of the substance or reactants before and after the reaction takes place. This can be done using a balance or other measuring device.
3. What are some factors that can affect the rate of change in mass in a substance or chemical reaction?
Temperature, pressure, concentration of reactants, and surface area are some of the factors that can affect the rate of change in mass in a substance or chemical reaction. The presence of a catalyst can also greatly impact the rate of reaction.
4. How does temperature affect the rate of change in mass in a substance or chemical reaction?
Generally, an increase in temperature will lead to an increase in the rate of change in mass in a substance or chemical reaction. This is because higher temperatures provide more energy for molecules to collide and react, resulting in a faster reaction rate.
5. Can the rate of change in mass in a substance or chemical reaction be reversed?
In most cases, the rate of change in mass in a substance or chemical reaction cannot be reversed. Once a reaction has occurred and products have been formed, it is very difficult to revert the products back to the original reactants. However, the rate of change in mass can be slowed down or even stopped by changing the conditions of the reaction.
