Substitute PID Controls with a Polynomial Equation/Table?
Using a polynomial equation or table to substitute PID controls may seem appealing, but it lacks the historical and trend analysis capabilities of PID controllers. A polynomial approach would require multiple constants and would primarily rely on current error, failing to address long-term errors or external disturbances. PID controllers utilize three distinct gain terms—Ki, Kp, and Kd—to manage cumulative error, current error, and error trends, which are essential for effective control. The polynomial method risks producing zero output when the setpoint is reached, leading to potential instability. Overall, while innovative, the polynomial approach does not adequately replace the established effectiveness of PID control systems.
Jay_
TL;DR Summary
TL;DNR: Would it be as effective to just use a polynomial function that is interpolated from an input-error-to-controller-output table instead of the effort of tuning gains of a PID controller?
So, I had a discussion with a friend of mine, neither of us are in controls but I was curious about an answer here. In a PID controller, we essentially take in an error value, do a mathematical operation on it and determine the input (controller output signal B) needed to the actuator to produce a desired output (position, temperature etc) based on the error (controller input signal A). This output from the actuator, is read by a sensor and fed back to generate the error and so on till it singles in on the setpoint value (position, temperature etc).
Now as a substitute to this whole thing, could we create a table of the desired error and controller output response, and then interpolate it have a polynomial function? So we close in on the set point more aggressively when the error is high, and less when it's lower. And we could just define this mathematically.
The only thing I could think of as to why this isn't as good is because a PID controller defines three variables (Ki, Kp and Kd), while this polynomial function would required probably 8 or 10 constants depending on the degree of the polynomial needed to make the controls good enough for our application. But are there any other reasons why this polynomial function approach (based on a table), wouldn't be preferred over tuning a PID controller?
A PID controller keeps track of history in the computation of the integral and the derivative. If you only have the proportional value, then the system cannot be controlled by a single input polynomial. For example, without the integral you could not eliminate a long term wandering DC error.
  • Love
Likes Phynoxum, DaveE, dlgoff and 2 others
Yes, what you are describing is still just proportional control. The problem lies in the fact that your goal is to have zero error, so as you approach your desired setpoint, your whole polynomial will approach zero, no mater how many terms it has. Think of it like a gas pedal. if you set your desired speed at 65, once you reach that speed, your polynomial will be equal to zero, meaning you will be giving it no gas. you will always need a non-zero error to have a non-zero input.
The other problem is that there are external disturbances in your system that will affect the output. To use the car example again, suppose you are on a long, straight, flat, deserted highway. You do some experiments and find that at 20% gas pedal, you're going 25 mph, at 40% gas pedal you're going 45 mph, etc. You can put that in a chart and interpolate, and you'll have your formula. However, the next time you're in the car, you're shuttling the entire wrestling team with all their luggage to the airport. And you're driving up a hill, in a huge headwind. Your chart will say you only need 58% gas to maintain highway speed, but you are barely topping 30 mph.
Likes Phynoxum and DaveE
It's a great question. But as you said "neither of us are in controls". The previous answers are great. If you want to understand the basics of control systems, you will need to study control systems a little bit. Be careful of ideas that may replace older established methods if their proponents haven't actually understood those methods (i.e. the state of the art).
PID controllers aren't just defined by Ki, Kp, and Kd. Those constants are gain terms applied to very different control laws. Ki is applied to knowledge of the error history (integrated, or cumulative, error). Kp is applied to knowledge of the current error. Kd is applied to knowledge of the trend (slope, derivative, rate of change, etc.) of the error. Your system only uses the current error, without knowledge of it's history or trend.
I'll also add that PID controllers are absolutely not "state of the art" they are just generally useful and easy to understand. Real control system engineers are working at a more general and fundamental level, which I'll call pole/zero placement in compensation networks. In the "PID" lingo, I have designed several feedback systems that I'll describe as IPDPIP, but most are just PI, which is usually good enough. This isn't as scary as it sounds if you know the fundamentals.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
