Substitution for double integrals
In summary, the task is to find a transform T that maps a unit square in the u-v plane to a quadrilateral with corners (1,2), (3,3), (4,2), and (2,1) in the x-y plane. The goal is to create a linear matrix M with offset u and use the known transformations to find the values for a, b, c, d, u, and v that will represent the transformation.
WhataRecch
Find a transform T that maps the unit square in the u-v plane to a quadrilateral with corners (1,2), (3,3), (4,2) and (2,1) to the x-y plane.
I've been able to create the proper region in the x-y plane when I have the transform T, but I have no clue how to come up with the transform in this case. The furthest I've gotten was coming up with the equations for the four sides in the quadrilateral, but I still hit a dead end.
so let's say
T(0,0) = (1,2)
T(1,0) = (4,2)
T(0,1) = (2,1)
T(1,1) = (3,3)
try writing out the transformation, T as a linear matrix M with offset u. take an intial point p.
then let's express it as
[tex]
T(\vec{p}) = M \vec{p} + \vec{u}
[/tex]
writing it out components explicitly
[tex]
T(p,q) = \begin{pmatrix} a & b \\ c & d\end{pmatrix} \begin{pmatrix} p \\ q \end{pmatrix} + \begin{pmatrix} u\\ v \end{pmatrix}
[/tex]
(p,q) is the initial point
then use the known transformations to find a,b,c,d,u,v
hopefully this is sufficient to represent your transformation
FAQ: Substitution for double integrals
What is substitution for double integrals?
Substitution for double integrals is a method used in mathematics to solve integrals with multiple variables. It involves changing the variables in an integral to simplify the expression and make it easier to evaluate.
Why is substitution for double integrals useful?
Substitution for double integrals is useful because it allows us to solve more complex integrals by reducing them to simpler forms. It can also help us find solutions to integrals that may otherwise be difficult or impossible to solve.
How do you perform substitution for double integrals?
To perform substitution for double integrals, you first need to identify which variables to substitute. Then, you need to find the Jacobian determinant of the transformation, which is used to change the variables in the integral. Finally, you can rewrite the integral with the new variables and evaluate it.
What are some common substitutions used for double integrals?
Some common substitutions used for double integrals include polar coordinates, cylindrical coordinates, and spherical coordinates. These substitutions are often used when the function being integrated has a circular or spherical symmetry.
What are the benefits of using substitution for double integrals?
Besides making integrals easier to solve, substitution for double integrals can also help us find geometric interpretations of the integral. It can also be used to solve problems in physics and engineering, such as calculating the volume of a solid with irregular boundaries.
