MHB Substitution Method to solve linear simultaneous equation
The discussion focuses on solving a system of linear equations using the substitution method. The user transformed the equations into a common denominator and derived two equations: 5y - 5x = 1 and 5y + 2x = 5. After substituting, they found x = 4/7, but expected the solution to be x = 0. A suggestion was made to multiply the first equation by 6 and simplify to potentially correct the solution. The conversation highlights the importance of careful manipulation of equations in the substitution method.
Yazan975
What I have done:
I changed all fractions to common denom and that gave me
5y-5x=1 (1) *I numbered the fractions
5y+2x=5 (2)
Then: 5y=5-2x
Substitute into equation 1
(5-2x)-5x=1
5-7x=1
x=4/7
Thing is my answer says I should be getting x=0
Any hints?
Mathematics news on Phys.org
When you multiply the first equation by $6$ and simplify, you should get $y-5x=1$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
