Substitution to convert first order ODE to homogenous
In summary, the equation ##\frac{dy}{dx}=\frac{2x+y-3}{x-2y+1}## can be transformed into a homogeneous equation ##\frac{dY}{dX}=\frac{2X+Y}{X-2Y}## by using the substitution ##x=X+h## and ##y=Y+k##. The process involves using the chain rule and the fact that both x and y have a slope of 1 in the new equation.
stfz
35
Use the substitution ##x=X+h## and ##y=Y+k## to transform the equation
##\frac{dy}{dx}=\frac{2x+y-3}{x-2y+1}## to the homogenous equation
Find h and k and then solve the given equation
If I simply make the substitution into the equation, I get a homogenous equation which I can solve using y=vx substitution. But what I need help understanding is how the ##\frac{dy}{dx}## becomes ##\frac{dY}{dX}## after simply substituting into the LHS?
Is some proof or method of doing this so that I can turn dy/dx into dY/dX and vice versa? The chain rule doesn't help, as I cannot relate X and Y
First [tex]\frac{dY}{dx}= \frac{d(y- k)}{dx}= \frac{dy}{dx}[/tex]
Now use the chain rule. [tex]\frac{dY}{dX}= \frac{dY}{dx}\frac{dx}{dX}= \frac{dy}{dx}(1)[/tex]
The real point is that both x= X+ h and y= Y+ k are linear with slope 1.
FAQ: Substitution to convert first order ODE to homogenous
What is substitution to convert first order ODE to homogenous?
Substitution is a technique used in solving first order ordinary differential equations (ODEs) to convert them into homogenous equations. This is done by replacing the dependent variable with a new variable and then solving the resulting equation. The resulting solution is then substituted back into the original equation to obtain the solution.
Why is it necessary to convert a first order ODE to homogenous?
Converting a first order ODE to homogenous form simplifies the equation and makes it easier to solve. It also allows for the use of standard methods such as separation of variables or substitution to find the solution.
What is the substitution method for converting a first order ODE to homogenous?
The substitution method involves replacing the dependent variable with a new variable, usually of the form y = vx, where v is a new function of x. This leads to a new equation that can be solved using standard methods. The resulting solution is then substituted back into the original equation to obtain the final solution.
What are the benefits of using substitution to convert a first order ODE to homogenous?
Using substitution to convert a first order ODE to homogenous allows for the use of standard methods to solve the equation, making it easier and more straightforward. It also simplifies the equation, making it easier to understand and work with.
Are there any limitations to using substitution to convert a first order ODE to homogenous?
One limitation of using substitution is that it may not always be possible to find a suitable substitution that converts the equation to a homogenous form. In such cases, alternative methods such as integrating factors or variation of parameters may be needed to solve the equation.
