MHB Subtracting mixed fractions help
To subtract mixed fractions, convert them to improper fractions first. The example given is four and five-ninths minus two-thirds, which is calculated as 41/9 minus 2/3. Finding a common denominator leads to 41/9 minus 6/9, resulting in 35/9. This improper fraction can then be converted back to a mixed fraction, yielding three and eight-ninths as the final answer. The steps demonstrate the process of subtraction and conversion clearly.
botswana
Hi, I'm new. Please bear with me because I'm not familiar with the code of this forum.
I don't know how to enter a mixed fraction correctly, so I'm just going to write it out. Here is the problem:
Four and five-ninths minus 2/3
Can someone explain to me why the answer is three and eight-ninths? I know that's the answer because the textbook I'm using says so, but I haven't been able to figure out why.
Mathematics news on Phys.org
I would convert to improper fractions:
$4\frac{5}{9}-\dfrac{2}{3}=\dfrac{9\cdot4+5}{9}-\dfrac{2}{3}=\dfrac{41}{9}-\dfrac{2}{3}$
Now, get a common denominator:
$$\frac{41}{9}-\frac{2}{3}\cdot\frac{3}{3}=\frac{41}{9}-\frac{6}{9}=\frac{41-6}{9}=\frac{35}{9}$$
Now express as a mixed fraction:
$\dfrac{35}{9}=\dfrac{3\cdot9+8}{9}=3+\dfrac{8}{9}=3\frac{8}{9}$
Does that make sense?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
