Subtracting two vectors -- I'm not getting the right answer
The discussion revolves around the subtraction of two vectors, specifically vector a and vector b, where vector a is horizontal and vector b has an angle of 120 degrees. The user is struggling to find vector c, which is defined as c = b - a. Participants suggest breaking down the vectors into their x and y components to facilitate the subtraction process. The importance of showing work and using the Pythagorean theorem for calculations is emphasized. Clarification on the components will help resolve the user's confusion.
Aleksa
I have vector a=3 that is horizontal and vector b=3 with an angle of 120. They have same direction. I need to find c=b-a.
Pythagorean theorem
I added x and y-axis so it would be square, and then vector bx would be same as vector a, but a didn't get it right. I am out of ideas. Can you help me?
:welcome:
I'm not sure I understand your question. Could you post a diagram of your vectors ##\vec a## and ##\vec b## and your attempt to find ##\vec c##?
Aleksa said:
Homework Statement:: I have vector a=3 that is horizontal and vector b=3 with an angle of 120. They have same direction. I need to find c=b-a.
Relevant Equations:: Pythagorean theorem
Welcome to PF.
What are the x and y components of each vector? What do you get when you do the vector subtraction component-wise? Please show your work. Thanks.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
