Subtraction and division problem: volume of 3 balls in cylinder
In summary, the conversation discusses the volume of three identical balls inside a cylindrical can, with the balls touching the bottom and top of the can. The formula for the volume of a sphere is given, and the question asks for the fraction of the can's volume taken up by the balls. The solution involves calculating the volume of the three balls and the cylinder, and using a ratio rather than subtraction to determine the fraction.
zak100
462
Three identical balls fit snugly into a cylindrical can: the radius of spheres equals the radius of can, and the balls just touch the bottom and the top of the can,
If the formula for the volume of a sphere is
V = 4/3 PI * radius * radius * radius, what fraction of the volume of the can is taken up by the balls?
Volume of sphere = 4/3 PI * r * r * r
Volume of cylinder = PI * r * r * h
Suppose diameter of each ball is 2 so r = 1.
Vol of 3 balls = 3 * 4/3 PI * r * r *r = 4 * PI
Note h = 6 because 3 balls can fit in the cylinder
Volume of cylinder = 6 * PI
volume take up by balls is= 6* PI - 4 * PI = 2 PI
book is not doing subtraction.,
Some body please guide me why are we not doing subtraction.
Zulfi.
Zulfi.
The question is "what fraction of the volume", so you would use a ratio to get the answer, not a subtraction. :smile:
Hi,
Thanks. I was also thinking on those lines but you have removed my confusion.
Zulfi.
FAQ: Subtraction and division problem: volume of 3 balls in cylinder
What is the formula for finding the volume of a cylinder?
The formula for finding the volume of a cylinder is V = πr2h, where r is the radius of the base and h is the height of the cylinder.
How do we use subtraction and division to solve for the volume of 3 balls in a cylinder?
To find the volume of 3 balls in a cylinder, we first need to subtract the volume of each ball from the total volume of the cylinder. Then, we can divide the remaining volume by 3 to get the volume of each ball.
Can we use the same formula for finding the volume of different shapes?
No, the formula for finding the volume of a cylinder is specific to cylinders. Different shapes have different formulas for finding their volumes.
How can we determine the radius and height of a cylindrical container if we know its volume?
If we know the volume of a cylindrical container, we can rearrange the formula V = πr2h to solve for either the radius or the height. If we have the radius, we can solve for the height by dividing the volume by πr2. If we have the height, we can solve for the radius by dividing the square root of the volume by πh.
What are some real-life applications of using subtraction and division to find the volume of objects?
Finding the volume of objects using subtraction and division is used in a variety of real-life situations, such as calculating the amount of liquid in a container, determining the amount of storage space needed for packing items, and measuring the displacement of water in a swimming pool. It is also commonly used in engineering and construction for designing structures and calculating materials needed for a project.
