Subtraction point not physical mass
In summary, there is a discussion about conventional renormalization and BPZ renormalization, and the possibility of choosing a subtraction point besides the physical mass for the self-energy. It is mentioned that the physical mass can be defined from the renormalized self-energy and the finite mass that depends on the energy scale μ. Textbooks often manipulate the self-energy directly and define the physical mass from it, while the conversation suggests a more convenient approach for calculating the self-energy correction.
geoduck
258
In conventional renormalization, for the self-energy, is it possible to make a subtraction from a point not equal to the physical mass?
[tex]\frac{1}{p^2-m_o^2-\Sigma(\mu^2)-\Sigma'(\mu^2)(p^2-\mu^2)-...} [/tex]
Now define [itex]m_o^2+\Sigma(\mu^2)\equiv m(\mu^2) [/itex]
Then:
[tex]\frac{1}{p^2-m(\mu)^2-\Sigma'(\mu^2)(p^2-\mu^2)-...} [/tex]
But you can't seem to write this in the form [itex]\frac{Z}{p^2-m(\mu)^2-\text{finite}}[/itex]
unless you choose [itex]\mu^2=m(\mu^2) [/itex]. But this choice corresponds to the physical mass.
But in BPZ renormalization, you have no problems working with a mass that depends on scale μ, and a scale is like a subtraction point is it not?
It is possible to choose a subtraction point besides the physical mass. I'm not familiar with how you're writing the self-energy (what's the utility in expanding about [itex]p^2 = \mu^2[/itex]?), but writing the bare propagator as
$$ \frac{1}{p^2-m_o^2-\Sigma_{0}(p^2)} $$
we can choose any subtraction scheme to obtain a finite self energy [itex]\Sigma_R[/itex], and then simply write the propagator as
$$ \frac{1}{p^2-m_R^2-\Sigma_{R}(p^2)} .$$
Now [itex]m_R[/itex] is a parameter dependent on your subtraction scheme, and thus dependent on [itex]\mu[/itex], and it will take the value [itex]m_R^2 = m_P^2 - \Sigma_R(m_P^2)[/itex]. The dependence of renormalized mass on the energy scale [itex]\mu[/itex] is physically important, especially for studying critical exponents.
EDIT: And of course, the [itex]\mu[/itex] dependence of [itex]Z = (1-\Sigma'_R(m_P^2))^{-1}[/itex] is also very important
Textbooks start with the bare propagator as you have, but then make an expansion about the physical mass:
$$ \frac{1}{p^2-m_o^2-\Sigma_{0}(p^2)}=\frac{1}{p^2-m_o^2-\Sigma_{0}(m_p^2)-\Sigma'_{0}(m_p^2)(p^2-m_p^2)-...} $$
They then say the definition of the physical mass is that [itex]m_o^2+\Sigma_{0}(m_p^2)=m_p^2 [/itex], so that
$$ \frac{1}{p^2-m_o^2-\Sigma_{0}(p^2)}=\frac{1}{p^2-m_o^2-\Sigma_{0}(m_p^2)-\Sigma'_{0}(m_p^2)(p^2-m_p^2)-...}=
\frac{1}{(p^2-m_p^2)-\Sigma'_{0}(m_p^2)(p^2-m_p^2)-...}
Then the (1-Ʃ')-1 can be factored out, which is Z:
=\frac{(1-\Sigma'(m_p))^{-1}}{(p^2-m_p^2)-\Sigma_{R}(p^2)}
That is how they got the relation: Z=(1-Ʃ')-1.
But this doesn't seem to work if Taylor expand Ʃ about a different point than the physical mass.
So textbooks basically manipulate Ʃ0 directly and define the physical mass from it, whereas you define the physical mass from the renormalized ƩR and the finite m2(μ).
If you will calculate the self energy correction by taking into account the inifinities of diagram and use some identity like 1/A+B=1/A-(1/A)B(1/A)+... you will see the result getting around the physical mass.This idea is just translated into a much convenient way without doing it always .They make an expansion around physical mass because that is the way it comes around.
FAQ: Subtraction point not physical mass
What is "Subtraction point not physical mass"?
"Subtraction point not physical mass" refers to the concept of subtracting a value from a point that does not have a physical mass or substance. This can occur in mathematical or scientific equations where the value being subtracted does not represent a tangible object or physical quantity.
Why is it important to understand "Subtraction point not physical mass"?
Understanding this concept is important in order to accurately interpret and solve mathematical or scientific equations. It can also be relevant in fields such as physics and engineering, where calculations involving points and mass are common.
Can "Subtraction point not physical mass" be applied to all types of equations?
Yes, this concept can be applied to a variety of equations in different fields of science and mathematics. It is often used in equations involving vectors, forces, and distances.
How does "Subtraction point not physical mass" differ from regular subtraction?
The main difference is that regular subtraction involves subtracting a physical quantity or number from another physical quantity or number. "Subtraction point not physical mass" involves subtracting a non-physical quantity from a point that does not have a physical mass.
Are there any real-world applications of "Subtraction point not physical mass"?
Yes, this concept can be applied in real-world scenarios such as calculating the displacement of an object or the resultant force acting on an object. It can also be used in computer graphics and 3D modeling, where points are represented by mathematical coordinates.
