Suction caused by an air jet acting on a plate, why?
In summary, the conversation discusses an experiment involving a vertical air jet and a plate positioned at various heights above it. At a certain distance, the plate experiences an upthrust from the air jet, but at a closer distance it experiences a suction force. This could be due to the pressure and flow of the air around the plate. One possible explanation is the creation of vortices due to the radial flow of air past the edges of the plate. Visualizing the flow with a streamer could help better understand this phenomenon.
ritchT
We set up in a lab a vertical pointing air jet giving a constant output and gradually increased the height of the plate above the jet whilst measuring the force upon it as imparted by the jet using a Newton-metre. At a big distance the air jet was imparting an upthrust on the plate but when the plate was around 5cm from the exit of the air jet the plate was subjected to a suction force.
How can this be possible, is it something to do with the pressure above and below the plate?
Thanks for any explanation
Is this a flat plate? One possible effect is that the flow is directed radially outwards from the center of the plate. This causes a reduction in pressure of that flow as the radius of the flow increases. If the pressure of that radial flow were reduced below ambient, then it would tend to draw the surrounding air due to pressure differential and viscosity, and the radial flow past the edges could result in vortices. Somehow all of these combined effects are reducing pressure.
Is there some way you can put a small streamer at the end of a thin rod and position the streamer at various points near the plate to visualize the flow?
Related to Suction caused by an air jet acting on a plate, why?
1. What is suction caused by an air jet acting on a plate?
Suction caused by an air jet acting on a plate is a phenomenon where a plate experiences a force towards the direction of the air jet due to the difference in air pressure on either side of the plate.
2. What causes suction in this scenario?
Suction is caused by the Bernoulli's principle, where an increase in the velocity of a fluid results in a decrease in its pressure. In this case, the air jet creates a low-pressure zone on one side of the plate, causing the plate to be pulled towards it.
3. How does the size of the air jet affect the suction force?
The larger the size of the air jet, the greater the suction force. This is because a larger air jet creates a larger low-pressure zone, resulting in a greater difference in pressure between the two sides of the plate.
4. Can suction caused by an air jet be reversed?
Yes, suction caused by an air jet can be reversed by changing the direction of the air jet. If the air jet is directed towards the opposite side of the plate, the plate will experience a repulsive force away from the air jet.
5. Are there any real-world applications of suction caused by an air jet acting on a plate?
Yes, there are several real-world applications of this phenomenon. It is commonly used in industries such as manufacturing, transportation, and aerospace to control the movement and positioning of objects. It is also used in vacuum cleaners and air pumps to create suction for cleaning and pumping purposes.
15K
