Suction side and discharge side pump pressure
In summary: If the vessel is connected near the discharge side, then the discharge pressure will be constant and the suction pressure will be 1,4bar.In summary, the static pressure before the pump starts is 2.0 bars and the system head loss is 0.6 bars. The suction side and discharge pressure will read half of the total head loss (1.7 and 2.3 bars) only if the resistance to flow is equal upstream and downstream of the atmospheric pressure refill. Otherwise, the head loss will be split unequally depending on the location of the expansion vessel in the central heating system.
TSN79
424
Consider a closed system (central heating). Before the pump is started the static pressure is 2.0 bars. Say the system head loss is 0.6 bars. When the pump starts, will the suction side pressure and the discharge pressure each read half the total head loss (1.7 and 2.3 bars)? Or will the head loss be split unequally for some reason?
Depends if the resistance to flow is upstream or downstream of the atmospheric pressure refill - or what fraction is upstream versus downstream.
In a central heating system there should exist an expansion vessel. The point that the vessel is connected to the piping determines the pressures at the various point of the network.
More specifically, if the vessel is correctly inflated, it keeps it's pressure constant (before and after the pump operation) and the connection point to the network keeps this pressure (2bar).
So, if the vessel is connected near the pump suction, then suction pressure will remain constant and the discharge pressure will be 2,6bar.
Related to Suction side and discharge side pump pressure
1. What is the difference between suction side and discharge side pump pressure?
Suction side pump pressure refers to the pressure at the inlet of the pump, where the fluid enters. Discharge side pump pressure is the pressure at the outlet of the pump, where the fluid exits. The difference between these two pressures is known as the pump head, which is the amount of energy the pump imparts to the fluid.
2. How is suction side pump pressure measured?
Suction side pump pressure is usually measured using a pressure gauge attached to the inlet of the pump. This gauge measures the pressure in pounds per square inch (psi) or bar.
3. What factors affect suction side pump pressure?
Suction side pump pressure can be affected by a variety of factors, including the speed of the pump, the viscosity of the fluid being pumped, the elevation difference between the fluid source and the pump, and the condition of the pump and its components.
4. How does suction side pump pressure impact pump performance?
Suction side pump pressure is an important factor in determining the efficiency and flow rate of the pump. If the suction side pressure is too low, it can cause cavitation, which can damage the pump and decrease its performance. On the other hand, if the suction side pressure is too high, it can put excessive strain on the pump and also decrease its efficiency.
5. Can suction side pump pressure be controlled?
Yes, suction side pump pressure can be controlled by adjusting the speed of the pump, using a pressure regulator or control valve, or by changing the fluid source or elevation. It is important to monitor and control suction side pump pressure to ensure the proper functioning and longevity of the pump.
  • Mechanical Engineering
