Suction Through Small & Large Pipes
In summary, the conversation discusses the relationship between the size of a vacuum's suction pipe and its suction power. The answer is not straightforward as there is no simple formula for this. The effectiveness of a vacuum cleaner depends on the volume of air shifted per second and the speed at which it moves into the nozzle, which can be affected by the size of the pipe. The best result for a given fan/motor will depend on the desired outcome. Additionally, the conversation touches on the demonstration of the "power" of vacuum cleaners by Electrolux and the use of Google for practical ideas. It is also mentioned that the suction pipe of a centrifugal pump does not necessarily have to be larger than the discharge pipe.
BradINewton
Hi,
I am wondering if suction power from a vacuum for example that has a set amount of power, is increased or decreased depending on the size of pipe. Does a large pipe decease/ increase the suction power, or does a small pipe decease/ increase the suction power? Is there a link to the size in diameter of a pipe and a vacuums suction power that gives the best results? To make the answer easier assume that the pipe is straight. Thanks for your help in advance and any help would be appreciated.
Good question! Welcome to PF.
The answer probably won't be very satisfactory for you, though because (i believe) there is no simple formula for this. The problem is with the term 'suction power', by which you probably mean 'effectiveness as a vacuum cleaner'. That, I guess, will be a combination of volume of air shifted per second and the speed at which it moves into the nozzle. You will notice that, if you partly or fully block off the end of your vac hose, the more the speed will increase. That implies that it is not doing as much work on the air with a small inlet hole - i.e. it is probably less effective. The fan is the thing that does the work and it will have been designed (/chosen) to shift a certain volume of air at a pressure difference at the nozzle. So the 'best' result, for a given fan / motor will depend on what you want. Do you want a lot of air over a big area (carpet or floor cleaning) or a smaller amount of his speed air ('crevice tool)?
Electrolux salesmen used to demonstrate the 'power' of their cylinder vacuum cleaners by removing the hose and holding the device inlet up to the ceiling. It would stay there! "Nothing sucks like an Electrolux" was their catch phrase. Langauge changes over the years!
Do you have a specific application in your question or is it just for interest?
Likes BradINewton
Hi,
Thanks for your quick response. I would say I want as good as suction as I can get from a rectangle area of 70mm x 300mm. The hose in question will travel into a head that is then spread across the area of 70mm x 300mm and will be used to suck up dirt (small/dust) and water. Thanks again.
What yo describe seems pretty much like the standard carpet attachment. Wouldn't that do?
If you need something for continuous running then an ordinary vacuum cleaner wouldn't be suitable. You would need something 'industrial' with an induction motor.
Have you tried google for some ideas" The Images option can help a lot with getting ideas for this sort of practical requirement.
The suction pipe of a centrifugal pump is not necessarily a larger bore (diameter)than the discharge pipe.
Suction lines are generally designed to keep friction losses to a minimum. This is in order to ensure sufficient available Net positive suction Head (NPSHa) to meet the NPSH required (NPSHr) by the pump.
Related to Suction Through Small & Large Pipes
1. What is suction through small and large pipes?
Suction through small and large pipes is the process of using a vacuum or negative pressure to move fluids through pipes of different sizes. This is commonly used in various industries, such as plumbing, agriculture, and manufacturing.
2. How does suction work in pipes?
In pipes, suction works by creating a pressure difference between the two ends of the pipe. This pressure differential causes fluids to move from areas of higher pressure to lower pressure, ultimately creating a flow through the pipe.
3. What are the factors that affect suction in pipes?
The factors that affect suction in pipes include the type and size of the pipe, the fluid being transported, the level of suction being applied, and any obstructions or bends in the pipe that may impede the flow.
4. What are the advantages of suction through small and large pipes?
Suction through small and large pipes offers several advantages, including the ability to move fluids quickly and efficiently, the ability to transport fluids over long distances, and the ability to control the flow rate and direction of the fluids.
5. What are the potential risks associated with suction in pipes?
The main risk associated with suction in pipes is the potential for air to be pulled into the system, which can cause cavitation and damage to the pipes or equipment. Additionally, if the suction is too strong, it can cause pipes to collapse or rupture.
  • General Engineering
  • Mechanical Engineering
  • Other Physics Topics
