MHB Sufficient Proof: $4 \nmid n^2 - 2$ for $r=0$
  • Thread starter Thread starter tmt1
    Proof
The discussion centers on proving that for integers n, the expression $4 \nmid n^2 - 2$ holds true when r = 0 in the context of the quotient remainder theorem. It is established that if n is a multiple of 4, then $n^2$ results in 0 mod 4, leading to $n^2 - 2$ being congruent to 2 mod 4, which is not divisible by 4. The argument is further supported by the observation that all perfect squares are either 0 or 1 mod 4, confirming that $n^2 - 2$ can only yield results of 2 or 3 mod 4. Thus, the conclusion is reached that for the case of r = 0, it is indeed sufficient to state that $4 \nmid n^2 - 2$.
tmt1
I would like to prove that this is incorrect:
$\exists x \in \Bbb{Z}$ such that $ 4 | n^2 - 2$
I can use the quotient remainder theorem,
$n = dq + r$ where $ 0 <= r < d $ and $ d = 4$
For the case $ r = 0$ is this sufficient proof?
$n = 4q $ and $4 | n^2 - 2$ thus $4 | 16q^2 - 2$
then $4 | 4(4q^2) + 2$
which can't be true, $\therefore $ for the case $ r = 0$, $4 \nmid n^2 - 2$
Is this sufficient for the case $r = 0$? (I can figure out the rest of the cases from here)
Mathematics news on Phys.org
There's no need to use the "quotient remainder theorem" (unless you've been directed to do so).
It's easily proved that all perfect squares are either 0 or 1 mod 4, thus n2 - 2 is 2 or 3 mod 4.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 21 ·
