MHB Sum involving pi, ln(2) and Catalan's constant
  • Thread starter Thread starter Sherlock1
    Constant Pi Sum
The discussion focuses on proving the relationship between a specific double sum and the integral involving logarithmic and trigonometric functions. It establishes that the sum of alternating series can be expressed as a combination of π, ln(2), and Catalan's constant, G. The integral of ln(1+x²)/(1+x²) from 0 to infinity is shown to equal π ln(2), leading to further simplifications. The integral is broken down into parts, revealing that the integral from 0 to 1 can be expressed in terms of G. The final result confirms that the series expansion aligns with the initial findings without requiring additional processing.
Sherlock1
Inspired by http://www.mathhelpboards.com/showthread.php?560-integrals thread: By considering the integral $\displaystyle \int_{0}^{\infty} \frac{\ln(1+x^2)}{1+x^2}\;{dx}$ or otherwise,
show that $\displaystyle \sum_{k \ge 0}~\sum_{0 \le j \le k}\frac{(-1)^k}{(2k+3)(j+1)} = \frac{1}{2}\pi\ln(2)-G$ where $G$ is Catalan's constant.
Mathematics news on Phys.org
In another post it has been demonstrated that...
$\displaystyle \int_{0}^{\infty} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx = \pi\ \ln 2$ (1)
Now with simple steps You can find that...
$\displaystyle \int_{0}^{\infty} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx = \int_{0}^{1} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx + \int_{1}^{\infty} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx = 2\ \int_{0}^{1} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx - 2 \int_{0}^{1} \frac{\ln x}{1+x^{2}}\ dx $ (2)
... so that is...
$\displaystyle \int_{0}^{1} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx = \frac{\pi}{2}\ \ln 2 + \int_{0}^{1} \frac{\ln x}{1+x^{2}}\ dx $ (3)
Some years ago I 'discovered' that is...
$\displaystyle \int_{0}^{1} x^{n}\ \ln x\ dx = -\frac{1}{(n+1)^{2}}$ (4)
... so that is...
$\displaystyle \int_{0}^{1} \frac{\ln x}{1+x^{2}}\ dx = - \sum_{n=0}^{\infty} \frac{(-1)^{n}}{(2n+1)^{2}} = - G$ (5)
... and finally...
$\displaystyle \int_{0}^{1} \frac{\ln (1+x^{2})}{1+x^{2}}\ dx = \frac{\pi}{2}\ \ln 2 -G$ (6)
Now find the series expansion of the definite integral in (6) is perfectly possible... but in my opinion is more elegant the (6) without any more 'processing'...
Kind regards
$\chi$ $\sigma$
Good job. Here's the series expansion done just for completion.
$\begin{aligned} \int_{0}^{1}\frac{\ln(1+x^2)}{1+x^2}\;{dx} & = \int_{0}^{1}\bigg(\sum_{k \ge 0}(-1)^kx^{2k}\bigg)\bigg(\sum_{k\ge 0}\frac{(-1)^kx^{2k+2}}{k+1}\bigg)\;{dx} \\& = \int_{0}^{1}\sum_{k \ge 0}~\sum_{0 \le j \le k} (-1)^{k-j}x^{2k-2j}\cdot\frac{(-1)^jx^{2j+2}}{j+1}\;{dx} \\& = \int_{0}^{1}\sum_{k \ge 0}~\sum_{0 \le j \le k} \frac{(-1)^k x^{2k+2}}{j+1}\;{dx} \\& = \sum_{k \ge 0}~\sum_{0 \le j \le k} ~\int_{0}^{1}\frac{(-1)^k x^{2k+2}}{j+1}\;{dx} \\& = \sum_{k \ge 0}~\sum_{0 \le j \le k} \frac{(-1)^k}{(j+1)(2k+3)}.\end{aligned}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
