Albert1
- 1,221
$\sum \dfrac{1}{n^2}, \,\, and \,\,\,\dfrac{61}{36}$ which one is bigger ?
Albert said:$\sum \dfrac{1}{n^2}, \,\, and \,\,\,\dfrac{61}{36}$ which one is bigger ?
very good solution Kaliprasad !kaliprasad said:assumption n is from 0 to infinite
the 1st term = $\dfrac{\pi^2}{6} \lt \dfrac{10}{6}$
$\dfrac{10}{6} = \dfrac{60}{36} \lt \dfrac{61}{36}$
so second term is bigger
solution:Albert said:very good solution Kaliprasad !
suppose $\sum \dfrac {1}{n^2} =\dfrac{\pi^2}{6} $ is not known yet , how can we compare those two numbers ?
The sum of 1/n2 is an infinite series that converges to approximately 1.6449. It is known as the Basel problem and was first solved by Leonhard Euler in the 18th century.
The sum of 61/36 is a finite number, specifically 1.6944. This can be calculated by dividing 61 by 36 using basic arithmetic.
The sum of 1/n2 is bigger than 61/36, as it converges to a larger value. However, since 61/36 is a finite number, it can be considered bigger in terms of absolute value.
The sum of 1/n2 is calculated using a mathematical formula known as the Basel problem, which involves summing an infinite series of fractions. This can also be approximated using numerical methods such as integration.
The sum of 1/n2 is significant because it is one of the first infinite series to be solved and has led to advancements in the study of calculus and number theory. It also appears in various mathematical concepts and has implications in physics and engineering.
