Sum of a closed set and a compact set, closed?
In summary, the conversation revolves around proving that X+Y is closed if X is compact and Y is closed, where X and Y are sets of real numbers. The key to the proof lies in the boundedness of a compact set and the fact that a sum of two closed sets may not necessarily be closed. The conversation includes discussing different definitions of the set X+Y and using examples to better understand the concept. The conversation also touches on topological groups and using the complement of X+Y to approach the proof. Ultimately, the conversation leads to the conclusion that if X is compact, then a subsequence of xi+yi, which converges to L, must have xi converging to an element of X, and yj must
utleysthrow
25
I am trying to prove that, if X is compact and Y is closed, X+Y is closed. Both X and Y are sets of real numbers.
I know that a sum of two closed sets isn't necessarily closed. So I presume the key must be the difference between the compact set and the closed set, namely the boundedness of a compact set. But I'm not sure how to exploit that fact for a proof.
Think about how the sum of two closed sets can fail to be closed, then explain why this can't happen if one of them is compact
If X=N and Y={-n+1/n} where n is a natural number, then both are closed but the sum X+Y={1/n} is not, since it doesn't include 0 which is a limit.
If one of them, say Y, is compact, this doesn't happen because {-n+1/n} has to be bounded by the definition of compactness, which means not all X=N is "canceled out" by the -n's in Y...
A+B would look something like 1, 1/2, 1/3 ... 4, 5, 6, ... which is still closed.
I feel like I only have a superficial understanding of this. I know it has to do with boundedness, but can't quite point to what it is without using a specific example... What am I missing?
Hi!
Your definition of the set X + Y doesn't correspond to my understanding. AFAIK, the standard definition is
X + Y = {x + y : x [itex] \in[/itex] X and y [itex] \in[/itex] Y}
With this definition, your set X + Y is still closed (since it doesn't contain the limit point 0), but it does contain points other than 1/n. Just wanted to mention this in case it helps.
Do you know about topological groups? I ask because (R, +), with R having the usual topology, is such a group. I probably could give you some hints on your problem if you know the basic definitions and theorems in this subject. Even if not, try proving that the complement of the set X + Y is open in R.
Let me know if any of the above is unclear, or if you want more help.
Petek
Petek said:
Hi!
Petek
[tex]X=N[/tex]
[tex]Y=\left\{ -n+\frac{1}{n} : n \in N \right\}[/tex]
[tex]X+Y=\left\{\frac{1}{n} : n \in N \right\}[/tex]
Thank you for your reply. Closed set, as far as I know, contains all of its limit points. Using that definition, my X+Y is not closed because 0 is a limit point of X+Y, but it is not contained in the set. Right?
I haven't learned about topological groups, but I'll try working with the complement of X+Y.
X+Y will contain for example the point 2+(-1+1)=2 The n you picked from X and the n you picked from Y don't have to be the same
So suppose you have a sequence in X+Y that does not converge to a limit point. Think about how you can use this sequence to talk about sequences in X and Y
Oh, right. I didn't catch that...
Now that I think about it... X+Y is still NOT closed even if it contains points other than 1/n, isn't it? That doesn't change the fact that 0 is still a limit point of X+Y, which is not contained in the set. Finding one limit point not in the set is all it takes to make the set NOT closed, no?
Yes, your set isn't closed. And finding one limit point not contained in the set makes it not closed. But you might be getting distracted from the original problem. If L is a limit point of X+Y then there is are sequences {xi} and {yi} such that xi+yi converges to L. If X is compact, what can you say about the sequence {xi}?
If X is compact, the seq {xi} should converge to some x [tex]\in X[/tex]
Not right. Can you rephrase that? [0,1] is compact. The sequence {0,1,0,1,0,1...} does not converge.
If X is compact... there is a subsequence of {xi} that converges to a limit x in X?
Much better. So there is a subsequence of xi+yi, which converges to L, call it xj+yj such that xj converges to M which is an element of X. Now what about yj? What must it converge to?
I would say that yj has to converge to L-M... but I'm not sure how to justify that. Does it simply follow from the fact that xj+yj converges to L, and xj converges to M, so (xj+yj)-xj=yj converges to L-M?
And if that is correct, it would follow that L-M is in Y since Y is a closed set. Then M+(L-M)=L is in X+Y
Sure it does. Use epsilons and deltas if you have to. But if yj converges to L-M, then is L-M in Y? Y is closed, right?
Yes. So X+Y is closed. Right?
Right. I have kind of a silly question though... how can we assume that xi+yi converges to anything?
We're assuming that X+Y is not closed. So there's a value
L such that xi+yi converges to L (xi+yi is some sequence of points in X+Y). We're assuming we pick a sequence that converges
Go back to post 9. We are taking L to be a limit point of X+Y because we want to show X+Y contains all of it's limit points. What's the definition of 'limit point'?
FAQ: Sum of a closed set and a compact set, closed?
What is a closed set and a compact set?
A closed set is a set that contains all of its limit points. This means that if a sequence of points within the set converges, the limit of that sequence must also be within the set. A compact set is a set that is both closed and bounded, meaning that it contains all of its limit points and can be contained within a finite region.
What does it mean to find the sum of a closed set and a compact set?
Finding the sum of a closed set and a compact set involves adding every element in the closed set to every element in the compact set. This results in a new set that contains all possible sums of the elements from the original two sets.
Why is the sum of a closed set and a compact set closed?
The sum of a closed set and a compact set is closed because it contains all of its limit points. Since both the closed set and the compact set contain all of their limit points, the sum of the two sets will also contain all of their limit points. This is a property known as closure under addition.
How is the sum of a closed set and a compact set related to the concept of convergence?
The sum of a closed set and a compact set is related to the concept of convergence because it involves adding together sequences of points from both sets. Convergence refers to the behavior of a sequence as it approaches a particular point, and adding these sequences together can result in new sequences that also converge to a particular point within the sum of the two sets.
Can the sum of a closed set and a compact set be a compact set?
Yes, the sum of a closed set and a compact set can be a compact set. This is because the sum of a closed set and a compact set is still bounded and closed, meaning that it still contains all of its limit points and can be contained within a finite region. Therefore, it meets the criteria for being a compact set.
