Sum of a series from n=1 to infinity of n^2/(2+1/n)^n
In summary: I also used a calculator to get the result it is 3.77381 but I am being ask to use a method to get to that result.Not sure any of this will help, but I played with the function ##f(x):=\sum_{n=1}^{\infty}n^2\left( 1+\tfrac{1}{2n}\right) ^{-n}\left( \tfrac{x}{2}\right) ^n##. Note that ##f(x)## satisfies the integral equation$$\int_{x_1=0}^{x}\int_{x_2=0}^{x_1}f(x
Frobenius21
Determine the sum of the series
Sum from n=1 to infinity of n^2/(2+1/n)^n
n^2/(2+1/n)^n
I tried to write it as n^2/2^n (1+1/2n)^n
But I am stuck there and don't know what to try next.Thanks for any help in advance!
Frobenius21 said:
Homework Statement:: Determine the sum of the series
Relevant Equations:: n^2/(2+1/n)^n
You need more parentheses. As you wrote it, it would be interpreted as ##\frac{n^2}{2^n}(1 + 1/2 \cdot n)^n##. What I think you meant was this:
##\frac{n^2}{2^n(1 + \frac 1 {2n})^n}##.
What tests do you know that you can use to test for convergence?
Thanks a lot, I am asked to find the sum of the series not to show if it converges.
How is possible to start with that?
If you're asked to show the sum of the series, then the series must necessarily be convergent.
Offhand, I don't have any ideas. Are there any similar examples in your textbook, or has your instructor shown you some similar examples in class?
A simple-minded way to find the sum of a series is to add a bunch of terms. If the series converges at a reasonable rate, you can get a pretty good estimate of the sum of the entire series. By adding up the first 25 terms (in Excel), I get a partial sum around 3.77.
Yes it should converge.
There are no similar examples that I know of. I am looking in textbooks to try to find something similar.
I'm tempted to regard this as [itex]f(1)[/itex] where
[tex]f(x) = \sum_{n=1}^\infty \frac{n^2}{(1 + \frac1{2n})^n}\left(\frac x2\right)^n[/tex]
Thanks
Can we have confirmation of what the question is - written out please.
Hi, I was just told to get the sum from n=1 to infinity of n^2/(2+1/n)^n
Does "get the sum" mean "get the exact value of the sum" or "get an approximate value of the sum"?
I don't have any ideas about how to get the exact value, but an approximate value is 3.77, as I described in post #4. @pasmith gave a hint earlier, but I don't see how that helps you get the exact value of the sum -- it's not a series that I recognize off the top of my head.
Thanks, I am just being ask to find a way to get the number of the sum
$$\int_{x_1=0}^{x}\int_{x_2=0}^{x_1}f(x_2 )\tfrac{dx_2 dx_1}{x_2 x_1}=\sum_{n=1}^{\infty}\left( 1+\tfrac{1}{2n}\right) ^{-n}\left( \tfrac{x}{2}\right) ^n$$
If somebody recognizes that sum on the right which *might* be a little nicer than the one we started with, "have integral equation, will travel..." Not sure where to go from here... we could also try a DE relation, but I'm stuck, I went in circles with the integral equation (proving something I already knew to start out with, oof!).
Related to Sum of a series from n=1 to infinity of n^2/(2+1/n)^n
1. What is the formula for the sum of a series from n=1 to infinity of n^2/(2+1/n)^n?
The formula for the sum of this series is S = ∑(n=1 to ∞) n^2/(2+1/n)^n.
2. How do you calculate the sum of this series?
To calculate the sum of this series, you can use the formula S = ∑(n=1 to ∞) n^2/(2+1/n)^n or you can use a calculator or computer program to evaluate the series for a given number of terms.
3. What is the convergence of this series?
This series converges, meaning that the sum of the series approaches a finite value as the number of terms increases.
4. What is the significance of the value of the sum of this series?
The sum of this series has no significant real-world application, but it is a common example used in calculus and mathematical analysis to demonstrate the concept of convergence.
5. Can you provide an example of how to use this series in a real-world scenario?
This series can be used to approximate the value of certain integrals in mathematics, but it does not have a direct application in real-world scenarios.
