Sum of Correlated Exponential RVs
In summary, the conversation discusses how to find the probability density function (pdf) of a random variable Y that is defined as the sum of three exponentially distributed random variables (X1, X2, and X3). The conversation mentions that if X1, X2, and X3 are independent, the pdf of Y can be found by convolving the individual pdfs. However, if X1, X2, and X3 are correlated, alternative methods such as simulation or fitting a polynomial to simulation data may be necessary to estimate the pdf of Y. The conversation also references several sources for further reading on this topic.
tpkay
Hi All :)
say Y = X1 + X2+ X3, where X1, X2 and X3 are each exponentially distributed RV. This makes Y also a RV. If X1 and X2 and X3 are independent, the pdf of Y can be found by the convolution of the individual pdfs.
What if X1, X2 and X3 are correlated? How do we go about finding the pdf of Y?
many thanks in advance
:-p
1. Simulate,
2. Fit a polynomial to simulation data.
Makarov, G. (1981) "Estimates for the distribution function of a sum of two random variables when the marginal distributions are fixed," Theory of Probability and its Applications, 26, 803-806.
See others under References in:
http://www.math.ethz.ch/%7Estrauman/preprints/pitfalls.pdf
Also see:
http://www.merl.com/publications/TR2006-010/
http://ieeexplore.ieee.org/Xplore/l...29369/01327853.pdf?isnumber=&arnumber=1327853
http://arxiv.org/abs/cond-mat/0601189
Hi there!
Great question. When dealing with correlated exponential RVs, we can no longer use the convolution method to find the pdf of Y. Instead, we can use the moment-generating function (MGF) of Y to find its distribution.
The MGF of Y is defined as E(e^tY) = E(e^t(X1+X2+X3)). By using the properties of exponential RVs, we can simplify this to E(e^tX1)E(e^tX2)E(e^tX3). Since X1, X2, and X3 are correlated, we can use their joint MGF to find the MGF of Y.
Once we have the MGF of Y, we can use it to find the moments of Y and therefore, the pdf of Y. Alternatively, we can use numerical methods such as Monte Carlo simulation to estimate the pdf of Y.
I hope this helps. Happy studying! 😃
FAQ: Sum of Correlated Exponential RVs
What is the definition of "Sum of Correlated Exponential RVs"?
The sum of correlated exponential random variables (RVs) refers to the sum of two or more exponential RVs that are correlated with each other. In other words, the values of the exponential RVs are not independent and are influenced by the values of the other RVs in the sum.
What is the significance of studying "Sum of Correlated Exponential RVs"?
Studying the sum of correlated exponential RVs is important in many fields such as probability theory, statistics, and engineering. It helps in understanding the behavior of correlated variables and their impact on certain outcomes. This knowledge can be applied in various real-world scenarios, such as risk assessment, financial modeling, and signal processing.
How is the "Sum of Correlated Exponential RVs" calculated?
The calculation of the sum of correlated exponential RVs involves using the correlation coefficient between the variables, along with their individual means and variances. This can be done using mathematical equations or through computer simulations.
What are some examples of real-world applications of "Sum of Correlated Exponential RVs"?
One example is in finance, where the returns of different stocks in a portfolio may be correlated, and their sum can help in predicting the overall performance of the portfolio. Another example is in wireless communication, where the sum of correlated exponential RVs can be used to model the interference caused by multiple signals.
Are there any limitations or assumptions when dealing with "Sum of Correlated Exponential RVs"?
One limitation is that the sum of correlated exponential RVs assumes a linear relationship between the variables. Additionally, the calculation may become more complex when dealing with a large number of RVs. Assumptions include the variables being normally distributed and the correlation coefficient being constant over time.
