Sum of eigenvectors of linear transformation
In summary, the space V=P_2(x) is the sum of eigenvectors of the linear transformation L: V\rightarrow V if and only if the eigenvectors of L form a basis for V. This means that the eigenvectors of L span V and can be used to represent any element of V.
gruba
206
Find all values [itex]a\in\mathbb{R}[/itex] such that vector space [itex]V=P_2(x)[/itex] is the sum of eigenvectors of linear transformation [itex]L: V\rightarrow V[/itex] defined as [itex]L(u)(x)=(4+x)u(0)+(x-2)u'(x)+(1+3x+ax^2)u''(x)[/itex]. [itex]P_2(x)[/itex] is the space of polynomials of order [itex]2[/itex].
-Eigenvalues and eigenvectors
First, we find the matrix of [itex]L[/itex] (choose a standard basis [itex]\{1,x,x^2\}[/itex]).
[tex]L(1)\Rightarrow L(u)(x)=0x^2+1x+4\Rightarrow [L(1)]= \begin{bmatrix}
4 \\
1 \\
0 \\
\end{bmatrix}[/tex]
[tex]L(x)=0x^2+1x-2\Rightarrow [L(x)]= \begin{bmatrix}
-2 \\
1 \\
0 \\
\end{bmatrix}[/tex]
[tex]L(x^2)=(2+2a)x^2+2x+2\Rightarrow [L(1)]= \begin{bmatrix}
2 \\
2 \\
2+2a \\
\end{bmatrix}\Rightarrow [L]_{\mathcal{B}}= \begin{bmatrix}
4 & -2 & 2 \\
1 & 1 & 2 \\
0 & 0 & 2+2a \\
\end{bmatrix}[/tex]
Next, we find eigenvalues and eigenvectors of [itex][L]_{\mathcal{B}}[/itex]:
[tex]\det([L]_{\mathcal{B}}-\lambda I)=(2+2a-\lambda)(\lambda-3)(\lambda-2)\Rightarrow[/tex] eigenvalues are [itex]\lambda_1=2+2a,\lambda_2=3,\lambda_3=2,a\neq 0,a\neq \frac{1}{2}[/itex].
Corresponding eigenvectors are [itex]v_1=\begin{bmatrix}
1 \\
1 \\
a \\
\end{bmatrix},v_2=\begin{bmatrix}
2 \\
1 \\
0 \\
\end{bmatrix},v_3=\begin{bmatrix}
1 \\
1 \\
0 \\
\end{bmatrix}[/itex].
What does it mean that the space [itex]V[/itex] is the sum of eigenvectors of [itex]L[/itex]?
4 \\
1 \\
0 \\
\end{bmatrix}[/tex]
-2 \\
1 \\
0 \\
\end{bmatrix}[/tex]
2 \\
2 \\
2+2a \\
4 & -2 & 2 \\
1 & 1 & 2 \\
0 & 0 & 2+2a \\
\end{bmatrix}[/tex]
1 \\
1 \\
a \\
2 \\
1 \\
0 \\
1 \\
1 \\
0 \\
##V## is the span or linear hull of eigenvectors of ##L##. It means the eigenvectors of ##L## build a basis of the three dimensional vector space ##V=P_2(x)##. (Assuming your calculations are correct.)
Related to Sum of eigenvectors of linear transformation
1. What is the sum of eigenvectors of a linear transformation?
The sum of eigenvectors of a linear transformation is a vector that represents the total effect of the linear transformation on all of its eigenvectors. It is calculated by adding together all of the individual eigenvectors, taking into account their respective eigenvalues.
2. Why is the sum of eigenvectors important in linear algebra?
The sum of eigenvectors is important because it allows us to understand the overall behavior of a linear transformation. By combining all of the individual eigenvectors, we can determine how the transformation affects the entire vector space.
3. How do you find the sum of eigenvectors for a specific linear transformation?
To find the sum of eigenvectors for a specific linear transformation, you first need to find all of the eigenvalues and eigenvectors of the transformation. Then, you can use the eigenvalues to scale each eigenvector and add them together to get the sum.
4. Can the sum of eigenvectors be used to determine the type of linear transformation?
Yes, the sum of eigenvectors can be used to determine the type of linear transformation. If the sum is equal to the original vector, then the transformation is a translation. If the sum is a scalar multiple of the original vector, then the transformation is a scaling. If the sum is a combination of both, then the transformation is a shear.
5. Is the sum of eigenvectors always a unique vector?
No, the sum of eigenvectors is not always a unique vector. If a linear transformation has multiple eigenvalues with the same value, then there may be multiple eigenvectors that correspond to those eigenvalues. In this case, the sum of eigenvectors will also have multiple possible values.
