How Do You Calculate the Sum of Fourth Powers Up to N?
  • MHB
  • Thread starter mathworker
  • Tags
    Sum
In summary: N, including using recursive relations and linear maps. One effective formula is to use the binomial coefficients and starting with the sum of 0 to n, which can be attributed to Gauss. However, the general formula was discovered by Blaise Pascal in 1654.
mathworker
111
how to find the sum,
\(\displaystyle 1^4+2^4...n^4\)
i tried myself but couldn't find an approach , when i googled it ifound the formula but not proof
Re: sum of fourth powers of N
A slow but elementary approach consists in the use of the recursive relation... $$ \binom{k+1}{1}\ s_{1} + \binom{k+1}{2}\ s_{2} + ... + \binom{k+1}{k} s_{k} = (n+1)^{k+1} - (n+1)\ (1)$$
... where...
$$s_{k}= 1^{k} + 2^{k} + ... + n^{k}\ (2)$$
Starting with $s_{1}= \frac{n\ (n+1)}{2}$ we obtain...
$$\binom{3}{1}\ \frac{n\ (n+1)}{2} + \binom{3}{2}\ s_{2} = (n+1)^{3} - (n+1) \implies s_{2}= n\ (n+1)\ \frac{2 n + 1}{6}\ (3)$$
$$\binom{4}{1}\ \frac{n\ (n+1)}{2} + \binom{4}{2}\ n\ (n+1)\ \frac{2 n + 1}{6} + \binom {4}{3}\ s_{3} = (n+1)^{4} - (n+1) \implies s_{3}= n^{2}\ \frac{(n + 1)^{2}}{4}\ (4)$$
$$\binom{5}{1}\ \frac{n\ (n+1)}{2} + \binom{5}{2}\ n\ (n+1)\ \frac{2 n + 1}{6} + \binom {5}{3}\ n^{2}\ \frac{(n + 1)^{2}}{4}+ \binom{5}{4}\ s_{4} = (n+1)^{5} - (n+1) \implies $$
$$ \implies s_{4}= n\ (n+1)\ (2 n + 1)\ \frac{3 n^{2}+ 3 n -1}{30}\ (5)$$
Of course it is possible to proceed with $s_{5}$, $s_{6}$, etc...
Kind regards
$\chi$ $\sigma$
One method to derive the formula would be to use the linear inhomogeneous recursion:
\(\displaystyle S_{n}=S_{n-1}+n^4\)
\(\displaystyle S_{n+1}=S_{n}+(n+1)^4\)
Subtracting the former from the latter (called symbolic differencing), we obtain:
\(\displaystyle S_{n+1}=2S_{n}-S_{n-1}+4n^3+6n^2+4n+1\)
\(\displaystyle S_{n+2}=2S_{n+1}-S_{n}+4(n+1)^3+6(n+1)^2+4(n+1)+1\)
Subtracting again, we get:
\(\displaystyle S_{n+2}=3S_{n+1}-3S_{n}+S_{n-1}+12n^2+24n+14\)
\(\displaystyle S_{n+3}=3S_{n+2}-3S_{n+1}+S_{n}+12(n+1)^2+24(n+1)+14\)
\(\displaystyle S_{n+3}=4S_{n+2}-6S_{n+1}+4S_{n}-S_{n-1}+24n+36\)
\(\displaystyle S_{n+4}=4S_{n+3}-6S_{n+2}+4S_{n+1}-S_{n}+24(n+1)+36\)
\(\displaystyle S_{n+4}=5S_{n+3}-10S_{n+2}+10S_{n+1}-5S_{n}+S_{n-1}+24\)
\(\displaystyle S_{n+5}=5S_{n+4}-10S_{n+3}+10S_{n+2}-5S_{n+1}+S_{n}+24\)
\(\displaystyle S_{n+5}=6S_{n+4}-15S_{n+3}+20S_{n+2}-15S_{n+1}+6S_{n}-S_{n-1}\)
We now have a homogeneous recurrence whose characteristic equation is:
\(\displaystyle r^6-6r^5+15r^4-20r^3+15r^2-6r+1=(r-1)^6=0\)
Since we have the root $r=1$ of multiplicity 6, we know the closed-form is:
\(\displaystyle S_n=k_1+k_2n+k_3n^2+k_4n^3+k_5n^4+k_6n^5\)
Now we may use initial values to determine the parameters $k_i$:
\(\displaystyle S_0=k_1=0\)
\(\displaystyle S_1=k_1+k_2+k_3+k_4+k_5+k_6=1\)
\(\displaystyle S_2=k_1+2k_2+4k_3+8k_4+16k_5+32k_6=17\)
\(\displaystyle S_3=k_1+3k_2+9k_3+27k_4+81k_5+243k_6=98\)
\(\displaystyle S_4=k_1+4k_2+16k_3+64k_4+256k_5+1024k_6=354\)
\(\displaystyle S_5=k_1+5k_2+25k_3+125k_4+625k_5+3125k_6=979\)
Solving this system, we find:
\(\displaystyle k_1=0,\,k_2=-\frac{1}{30},k_3=0,\,k_4=\frac{1}{3},\,k_5=\frac{1}{2},\,k_6=\frac{1}{5}\)
And so we may state:
\(\displaystyle S_n=-\frac{1}{30}n+\frac{1}{3}n^3+\frac{1}{2}n^4+\frac{1}{5}n^5=\frac{6n^5+15n^4+10n^3-n}{30}=\frac{n(n+1)(2n+1)(3n^2+3n-1)}{30}\)
thanks to both of you,
would you explain this relation...i know nothing about it
We start writing...
$$\displaystyle a_{j}= (j+1)^{k+1} - j^{k+1} = \sum_{i=0}^{k} \binom{k+1}{i}\ j^{i}\ (1)$$
... and then we evaluate...
$$\displaystyle \sum_{j=0}^{n} a_{j} = (n+1)^{k+1} = \sum_{i=0}^{k} \binom{k+1}{i} s_{i} \implies \sum_{i=1}^{k} \binom{k+1}{i}\ s_{i} = (n+1)^{k+1} - (n+1)\ (2)$$
Kind regards
$\chi$ $\sigma$
Anoher way:
[tex](a)\;T:\mathbb{R}_5[x]\rightarrow{\mathbb{R}_5[x]}[/tex] defined by [tex]T(p(x))=p(x+1)-p(x)[/tex] is a linear map.
$(b)\;$ If $Y=AX$ is the equation of $T$ with respect to the canonical basis of $\mathbb{R}_5[x]$, using [tex]x^4\equiv(0,0,0,0,1,0)^t[/tex] we get [tex]T^{-1}(x^4)\equiv (\alpha,-1/30,0,1/3,-1/2,1/5)^t[/tex] with [tex]\alpha \in \mathbb{R}[/tex] that is, $$T^{-1}(x^4)=\left\{{\alpha -x/30+x^3/3-x^4/2+x^5/5:\alpha \in{\mathbb{R}}}\right\}$$ $(c)$ Choose any polynomial [tex]h(x)\in{T^{-1}(x^4)}[/tex] (for example, the corresponding to [tex]\alpha=0[/tex]) . Such polynomial satisfies [tex]T(h(x))=x^4[/tex] i.e. [tex]h(x+1)-h(x)=x^4\;(*)[/tex]. For [tex]x=1,2,\ldots,n[/tex] in [tex](*)[/tex] we get:
[tex]
h(2)-h(1)=1^4\\
h(3)-h(2)=2^4\\
h(4)-h(3)=3^4\\
\ldots\\
h(n+1)-h(n)=n^4[/tex]
That is, [tex]h(n+1)-h(n)=1^4+2^4+\ldots+n^4=S_4[/tex], hence
[tex]S_4=h(n+1)-h(1)=\\-\displaystyle\frac{n+1}{30}+\displaystyle\frac{(n+1)^3}{3}-\displaystyle\frac{(n+1)^4}{2}+\displaystyle\frac{(n+1)^5}{5}+\displaystyle\frac{1}{30}-\displaystyle\frac{1}{3}+\displaystyle\frac{1}{2}-\displaystyle\frac{1}{5}[/tex]
Simplifying:
[tex]S_4=1^4+2^4+3^4+\ldots+n^4=\dfrac{n(2n+1)(n+1)(3n^2+3n-1)}{30}[/tex]
P.S. More details here: http://www.fernandorevilla.es/docencia-problemas/problemas-2/2-s_414-n4-y-endomorfismo
... where...
A more effective and elegant formula is...
$$ \binom {k+1}{0}\ s_{0} + \binom{k+1}{1}\ s_{1} + \binom{k+1}{2}\ s_{2} + ... + \binom{k+1}{k} s_{k} = (n+1)^{k+1}\ (1)$$
... where...
$$s_{k}= 0^{k} + 1^{k} + 2^{k} + ... + n^{k}\ (2)$$
Starting from $s_{0}= n+1$ [remember that $0^{0}$ is not an 'indeterminate form' but is $0^{0}=1$...] we obtain all the successive $s_{k}$ and in particular is $ n+1 + 2\ s_{1} = (n+1)^{2} \implies s_{1}= n\ \frac{n+1}{2}$. According to a very known anectode '... in 1787, when Gauss was only ten years old, his teacher had the students add up all the numbers from one to a hundred, with instructions that each should place his slate on a table as soon as he had completed the task. Almost immediately Gauss placed his slate on the table. The teacher looked at Gauss scornfully while the others worked diligently. When the instructor finally looked at the results, the slate of Gauss was the only one to have the correct answer, 5050, with no further calculation...', so that Gauss is considered as the 'discover' of the numerical value to $s_{1}$. Very well!... it could be interesting for someone of You to know that the general formula (1) was 'discovered' in the year 1654 [!] by the French matematician and philosopher Blaise Pascal... no comments? (Wasntme)...
Kind regards
$\chi$ $\sigma$
Hello, mathworker!
Here is a primitive procedure that should work
/ / for any polynomial function.
[tex]\text{Find the sum: }\:S_n \:=\;1^4+2^4+3^4+\cdots+n^4[/tex]
Crank out the first few sums:
. . [tex]\begin{array}{cc}n & S_n \\ \hline 1 & 1 \\ 2 & 17 \\ 3 & 98 \\ 4 & 354 \\ 5 & 979 \\ 6 & 2275 \\ 7 & 4676 \\ 8 & 8772 \end{array}[/tex]Take the difference of consecutive terms,
then the differences of the differences, and so on.
[tex]\begin{array}{cccccccccccccccccc}\text{Sequence} & 1 && 17 && 98 && 354 && 979 && 2275 && 4676 && 8772 \\ \text{1st diff.} && 16 && 81 &&256 && 625 && 1296 && 2401 && 4096 \\ \text{2nd diff.} &&& 65 && 175 && 369 && 671 && 1105 && 1695 \\ \text{3rd diff.} &&&& 110 && 194 && 302 && 434 && 590 \\ \text{4th diff.} &&&&& 84 && 108 && 132 && 156 \\ \text{5th diff.} &&&&&& 24 && 24 && 24 \end{array}[/tex]
We see that the 5th differences are constant.
Hence, the generating function is of the 5th degree.
The general 5th-degree function is: .[tex]f(n) \:=\:An^5 + Bn^4 + Cn^3 + Dn^2 + En + F[/tex]Substitute the first six values of the sequence:
[tex]\begin{array}{cccccc}f(1) = 1: & A+B+C+D+E+F &=& 1 \\ f(2) = 17: & 32A + 16B + 8C + 4D + 2E + F &=& 17 \\ f(3) = 98: & 243A + 81B + 27C + 9D + 3E + F &=& 98 \\ f(4) = 354: & 1024A + 256B + 64C + 16D + 4E + F &=& 354 \\ f(5) = 979: & 3125A + 625B + 125C + 25D + 5E + F &=& 979 \\ f(6) = 2275: & 7776A + 1296B + 216C + 36D + 6E + F &=& 2275 \end{array}[/tex]Solve the system of equations: .[tex]\begin{Bmatrix}A &=& \tfrac{1}{5} && D &=& 0 \\ B &=& \tfrac{1}{2} && E &=& \text{-}\tfrac{1}{30} \\ C &=& \tfrac{1}{3} && F &=& 0 \end{Bmatrix}[/tex]
Hence: .[tex]S_n \;=\;\tfrac{1}{5}n^5 + \tfrac{1}{2}n^4 + \tfrac{1}{3}n^3 - \tfrac{1}{30}n [/tex]Therefore: .[tex]\sum^n_{k=1} k^4 \;=\;\frac{n(6n^4 + 15n^3 + 10n^2 - 1)}{30}[/tex]
soroban said:
Hello, mathworker!
yeah, i got it thank you, but why should that happen
What is the $n$th derivative of an $n$th degree polynomial?
n factorial
Yes, if the leading coefficient is 1, but what I was getting at is that it is a constant...
how do we relate differences triangle with nth derivative
You should observe that a common theme in the various methods given above is differencing...how are differencing and differentiation related?
can't figure it out:confused:
What is the definition of the derivative?
change in the value of a function w.r.t an infinitesimally small change in the variable,
What if the change in the independent variable is 1?
change in the value of function ...but change in variable should be very small as per def
FAQ: How Do You Calculate the Sum of Fourth Powers Up to N?
What is the formula for finding the sum of fourth powers of N?
The formula for finding the sum of fourth powers of N is: (N*(N+1)*(2N+1)*(3N^2+3N-1))/30.
Why is the sum of fourth powers of N important in mathematics?
The sum of fourth powers of N is important in mathematics because it is used in various mathematical equations and concepts, such as the binomial theorem, calculus, and number theory.
Can the sum of fourth powers of N be negative?
Yes, the sum of fourth powers of N can be negative. This can happen when N is a negative number or when the sum contains both positive and negative terms.
What is the relationship between the sum of fourth powers of N and the sum of cubes of N?
The sum of fourth powers of N and the sum of cubes of N are related by the formula: (N*(N+1)/2)^2. This means that the sum of fourth powers is equal to the square of the sum of cubes.
How is the sum of fourth powers of N used in real-life applications?
The sum of fourth powers of N is used in real-life applications such as physics, engineering, and statistics. It is used to calculate moments of inertia, approximate areas under curves, and solve optimization problems.
