I Sum of the dot product of complex vectors
The discussion centers on the summation of components in complex vectors, specifically how to derive the expression for the total electric field vector, ##\widetilde{\vec{E_t}}##, from its components. The user is attempting to understand the relationship between the complex vector representation and its projection onto a specific direction, ##\hat{e_p}##. There is confusion regarding the notation used, particularly the definition of ##e_{p}*##, which is questioned as being a scalar rather than a vector. The user expresses uncertainty about reaching the final expression and seeks clarification on the notation and derivation process. Overall, the thread highlights the complexities of working with complex vectors in physics and the need for clear definitions in mathematical expressions.
happyparticle
Summary:: summation of the components of a complex vector
Hi,
In my textbook I have
##\widetilde{\vec{E_t}} = (\widetilde{\vec{E_i}} \cdot \hat{e_p}) \hat{e_p}##
##\widetilde{\vec{E_t}} = \sum_j( (\widetilde{\vec{E_{ij}}} \cdot {e_{p_j}}*) \hat{e_p}##
For ##\hat{e_p} = \hat{x}##
##\widetilde{\vec{E_{0i}}} = (E_{0x} \hat{x} \pm E_{0y} \hat{y} )e^{i\theta}##
Thus, ##\widetilde{\vec{E_0t}} = (\sum E_{0ij} e_{pj}*) \hat{e_p}##
and then
##\widetilde{\vec{E_0t}} = E_0 cos \theta \hat{x} + E_0 sin^* \theta (0) ##
I don't see how to get the last line. This is what I think.
##\widetilde{\vec{E_0t}} = [(E_{0x}e^{i \theta}] \hat{x}## where, ##e_{p}* = x - iy = 1## because ##\hat{e_p} = \hat{x}##
= ## E_{0x} (cos \theta + i sin \theta) \hat{x}##
I tried different way to get the same result, but I'm not sure to fully understand.
Hi,
and then
Shouldn't ep* be a vector?
You write ep* = x -iy. That's a scalar.
Too many undefined notational symbols to guess at, which textbook are you using?
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
