Sum of the Values of X, Exponential Equation
In summary, the equation (4x)^(1 + log(base 2) (x)) = 8(x^3) has a solution of x = 1/2 and therefore, the sum of the values of x that fulfill the equation is 1/2.
wiraimperia
What is the sum of the values of x that fullfill that equation?
A) 2.5
B) 2.0
C) 1.5
D) 1.0
E) 0.5
Use the exponential equation only and make the lower one (exponented) 1.
(4x) = (2 x^(1/2))^2
8(x^3) = (2x)^3
If I insert x = (1/4) to make 4x = 1 it doesn't fulfill the equation..
So does x = (1/2)..
I cannot simplify the exponential equation... Any assistance please?
hi wiraimperia! :smile:
(try using the X2 and X2 buttons just above the Reply box :wink:)
for any number n, what is nlog2(x) ? :wink:
[tex]4x(4x)^{\log_2x} = 8x^3[/tex]
... how many values of x satisfy the equation?
I'd recheck for x=1/2 ...
I mean if it has 2 solutions, then we are asked X1 + X2, if it has 3, then X1 + X2 + X3, and so on...
Try to take the logarithm of both sides.
ehild
for any number m, what is (2m)log2(x) ? :wink:
Is there any way you can figure out how many solutions it is likely to have?
Have you rechecked if x=1/2 is a solution? Personally I managed it by systematic guesswork using the list of possible solutions ... but I've had practice.
Have you tried any of the other suggestions and hints? They are all good.
Is there a particular method you are supposed to use or can we throw anything we like at the problem? eg. there's always brute-force methods like plotting the curves to get ballpark figures and then using Newton/Raphson ...
Taking logarithm on both sides with base 2, you get:
[tex](1+log_2 x)log_2(4x)=3+3log_2 x[/tex]
It is easy to solve now. :smile:
Related to Sum of the Values of X, Exponential Equation
1. What is the sum of the values of x in an exponential equation?
The sum of the values of x in an exponential equation depends on the specific equation being used. However, in general, the sum of the values of x will increase as x increases in an exponential equation.
2. How do you find the sum of the values of x in an exponential equation?
To find the sum of the values of x in an exponential equation, you can either manually calculate each individual value of x and then add them together, or you can use a calculator or computer program to solve the equation and obtain the sum.
3. Can the sum of the values of x in an exponential equation be negative?
It is possible for the sum of the values of x in an exponential equation to be negative, depending on the specific equation and the values of x used. However, in most cases, the sum will be positive as x is typically used as a positive variable in exponential equations.
4. How does changing the value of x affect the sum in an exponential equation?
Changing the value of x in an exponential equation will directly impact the sum of the values of x. As x increases, the sum will also increase, and as x decreases, the sum will decrease.
5. Can the sum of the values of x in an exponential equation be infinite?
In most cases, the sum of the values of x in an exponential equation will not be infinite. However, there are certain exponential equations where the sum can approach infinity as x increases without bound, such as in a geometric series.
