sihag
- 29
i was looking for a counter example.
and, I've not been able to think of any.
sihag said:i did not understand the geometric bit.
well i considered the principal ideals <2> and <3>
their union includes 1 which is a unit in Z, so the ideal of the sum is nothing but Z itself right ?
and that can't be prime by definition ? (since an ideal P is prime => P /= R (the ring in consideration))
more hints please.
Think of rings like R[x, y]. Algebraic curves (like the parabola y - x^2 = 0) correspond to ideals (like the ideal <y - x^2>). Sums of ideals relate to intersections of curves. Can you work out why? Do you see how a non-prime ideal corresponds, in some sense, into a curve that is the union of two or more other curves?sihag said:i did not understand the geometric bit.
A prime ideal in a commutative ring is an ideal that is not the whole ring and has the property that if the product of two elements is in the ideal, then at least one of the elements is in the ideal.
To prove that the sum of two prime ideals is prime, we must show that it is an ideal and that it is a prime ideal. To show that it is an ideal, we can use the definition of the sum of ideals. To show that it is a prime ideal, we can use the definition of a prime ideal and the fact that the sum of ideals is a subset of the product of ideals.
No, the sum of two prime ideals is always prime. This is because if the sum of two ideals is prime, then it is an ideal and a prime ideal, and the sum of two prime ideals is an ideal and a subset of the product of two prime ideals.
The sum of two prime ideals is important in ring theory because it allows us to define and study other important concepts, such as the radical of an ideal and the intersection of ideals. It also helps us understand the structure of rings and their ideals.
Yes, the sum of two prime ideals can be a maximal ideal. This occurs when one of the prime ideals is contained in the other, making their sum equal to the larger prime ideal. In this case, the sum of two prime ideals is a maximal ideal as it cannot be properly contained in any other ideal.
